[GRASS-QA] GRASS QA: glynn | ./grass6/lib/gis/area.c |no clones | 0
monsters | 0 warnings
grass-qa at proxy.soccerlab.polymtl.ca
Fri Apr 13 20:44:01 EDT 2007
Hello glynn,
ANALYSIS
lib/gis/area.c functions
G_begin_cell_area_calculations (Begins at: 49 Ends at: 93)
Complexity: | 6 | | OK |
ParamNBR: | 1 | | OK |
CalledNBR: | 6 | | OK |
LOC: | 45 | | OK |
metrics are OK
G_area_of_cell_at_row (Begins at: 96 Ends at: 128)
Complexity: | 3 | | OK |
CalledNBR: | 2 | | OK |
LOC: | 33 | | OK |
metrics are OK
G_begin_polygon_area_calculations (Begins at: 130 Ends at: 174)
CalledNBR: | 4 | | OK |
LOC: | 45 | | OK |
metrics are OK
G_area_of_polygon (Begins at: 176 Ends at: 186)
Complexity: | 2 | | OK |
ParamNBR: | 3 | | OK |
LOC: | 11 | | OK |
metrics are OK
Clone analysis:
This file does not contain cloned functions
Threshold GRASS6 key metrics values at 2007-04-13 are:
median | upper | outlier |
| quartile | limit |
Complexity (Cyclo): 5 | 25 | 37 |
ParamNBR: 2 | 6 | 9 |
CalledNBR: 10 | 60 | 87 |
LOC: 43 | 195 | 272 |
LOC: Lines Of Code
Message interpretation:
OK : Nothing to say at all
* : above 75 % of value warning
Brought to you by:
