[GRASS-QA] GRASS QA: glynn | ./grass6/lib/gis/quant.c |6 clones (
main.c main.c ask.c cats.c color_get.c color_rule.c env.c
key_value1.c quant.c )| 0 monsters | 0 warnings
grass-qa at proxy.soccerlab.polymtl.ca
Fri Apr 13 20:44:03 EDT 2007
Hello glynn,
ANALYSIS
lib/gis/quant.c functions
G_quant_clear (Begins at: 305 Ends at: 310)
Complexity: | 1 | | OK |
ParamNBR: | 1 | | OK |
CalledNBR: | 0 | | OK |
LOC: | 6 | | OK |
metrics are OK
G_quant_free (Begins at: 314 Ends at: 327)
Complexity: | 3 | | OK |
CalledNBR: | 4 | | OK |
LOC: | 14 | | OK |
metrics are OK
G__quant_organize_fp_lookup (Begins at: 331 Ends at: 422)
Complexity: | 9 | | OK |
CalledNBR: | 6 | | OK |
LOC: | 92 | | OK |
metrics are OK
G_quant_init (Begins at: 424 Ends at: 433)
CalledNBR: | 1 | | OK |
LOC: | 10 | | OK |
metrics are OK
G_quant_is_truncate (Begins at: 437 Ends at: 440)
LOC: | 4 | | OK |
metrics are OK
G_quant_is_round (Begins at: 444 Ends at: 471)
LOC: | 28 | | OK |
metrics are OK
G_quant_truncate (Begins at: 473 Ends at: 477)
LOC: | 5 | | OK |
metrics are OK
G_quant_round (Begins at: 481 Ends at: 485)
LOC: | 5 | | OK |
metrics are OK
quant_set_limits (Begins at: 489 Ends at: 498)
ParamNBR: | 5 | * | |
LOC: | 10 | | OK |
metrics are OK
quant_update_limits (Begins at: 502 Ends at: 538)
Complexity: | 2 | | OK |
LOC: | 37 | | OK |
metrics are OK
G_quant_get_limits (Begins at: 540 Ends at: 559)
LOC: | 20 | | OK |
metrics are OK
G_quant_nof_rules (Begins at: 563 Ends at: 567)
LOC: | 5 | | OK |
metrics are OK
G_quant_get_ith_rule (Begins at: 571 Ends at: 582)
ParamNBR: | 6 | * | |
LOC: | 12 | | OK |
metrics are OK
quant_table_increase (Begins at: 586 Ends at: 601)
CalledNBR: | 2 | | OK |
LOC: | 16 | | OK |
metrics are OK
G_quant_set_neg_infinite_rule (Begins at: 605 Ends at: 623)
ParamNBR: | 3 | | OK |
LOC: | 19 | | OK |
metrics are OK
G_quant_get_neg_infinite_rule (Begins at: 627 Ends at: 640)
LOC: | 14 | | OK |
metrics are OK
G_quant_set_pos_infinite_rule (Begins at: 644 Ends at: 662)
LOC: | 19 | | OK |
metrics are OK
G_quant_get_pos_infinite_rule (Begins at: 666 Ends at: 679)
LOC: | 14 | | OK |
metrics are OK
G_quant_add_rule (Begins at: 683 Ends at: 716)
LOC: | 34 | | OK |
metrics are OK
G_quant_reverse_rule_order (Begins at: 720 Ends at: 741)
LOC: | 22 | | OK |
metrics are OK
quant_interpolate (Begins at: 745 Ends at: 756)
LOC: | 12 | | OK |
metrics are OK
less_or_equal (Begins at: 759 Ends at: 763)
ParamNBR: | 2 | | OK |
LOC: | 5 | | OK |
metrics are OK
less (Begins at: 765 Ends at: 790)
LOC: | 26 | | OK |
metrics are OK
G_quant_get_cell_value (Begins at: 792 Ends at: 899)
Complexity: | 23 | * | |
CalledNBR: | 15 | | OK |
LOC: | 108 | | OK |
metrics are OK
G_quant_perform_d (Begins at: 903 Ends at: 917)
ParamNBR: | 4 | | OK |
CalledNBR: | 3 | | OK |
LOC: | 15 | | OK |
metrics are OK
G_quant_perform_f (Begins at: 921 Ends at: 935)
LOC: | 15 | | OK |
metrics are OK
double_comp (Begins at: 939 Ends at: 947)
Complexity: | 4 | | OK |
LOC: | 9 | | OK |
metrics are OK
G__quant_get_rule_for_d_raster_val (Begins at: 951 Ends at: 961)
LOC: | 11 | | OK |
metrics are OK
Clone analysis:
This file has 6 potentially cloned functions:
G_quant_set_pos_infinite_rule G_quant_set_neg_infinite_rule G_quant_get_pos_infinite_rule G_quant_get_neg_infinite_rule G_quant_perform_f G_quant_perform_d
In lib/gis/quant.c clones of G_quant_perform_f are:
lib/gis/quant.c G_quant_perform_d
In lib/gis/quant.c clones of G_quant_set_neg_infinite_rule are:
lib/gis/quant.c G_quant_set_pos_infinite_rule
In lib/gis/quant.c clones of G_quant_set_pos_infinite_rule are:
lib/gis/quant.c G_quant_set_neg_infinite_rule
In lib/gis/quant.c clones of G_quant_get_pos_infinite_rule are:
lib/gis/quant.c G_quant_get_neg_infinite_rule
In lib/gis/quant.c clones of G_quant_get_neg_infinite_rule are:
lib/gis/quant.c G_quant_get_pos_infinite_rule
In lib/gis/quant.c clones of G_quant_perform_d are:
lib/gis/quant.c G_quant_perform_f
Threshold GRASS6 key metrics values at 2007-04-13 are:
median | upper | outlier |
| quartile | limit |
Complexity (Cyclo): 5 | 25 | 37 |
ParamNBR: 2 | 6 | 9 |
CalledNBR: 10 | 60 | 87 |
LOC: 43 | 195 | 272 |
LOC: Lines Of Code
Message interpretation:
OK : Nothing to say at all
* : above 75 % of value warning
Brought to you by:
