[GRASS-QA] GRASS QA: glynn | ./grass6/lib/gis/nme_in_mps.c |no
	clones | 0 monsters | 0 warnings
    grass-qa at proxy.soccerlab.polymtl.ca
    Fri Apr 13 20:44:03 EDT 2007
Hello glynn,
ANALYSIS
lib/gis/nme_in_mps.c functions
G__name_in_mapset (Begins at: 18 Ends at: 28)
Complexity:   |       1 |       |      OK |
ParamNBR:     |       3 |       |      OK |
CalledNBR:    |       2 |       |      OK |
LOC:          |      11 |       |      OK |
metrics are OK
G__name_is_fully_qualified (Begins at: 31 Ends at: 92)
Complexity:   |       5 |       |      OK |
CalledNBR:    |       0 |       |      OK |
LOC:          |      62 |       |      OK |
metrics are OK
G_fully_qualified_name (Begins at: 95 Ends at: 107)
Complexity:   |       2 |       |      OK |
CalledNBR:    |       4 |       |      OK |
LOC:          |      13 |       |      OK |
metrics are OK
Clone analysis:
Threshold GRASS6 key metrics values at 2007-04-13 are:
                           | quartile  | limit   |
ParamNBR:                2 |         6 |       9 |
CalledNBR:              10 |        60 |      87 |
LOC:                    43 |       195 |     272 |
 LOC: Lines Of Code
Message interpretation:
 OK : Nothing to say at all
Brought to you by:
