[GRASS-QA] GRASS QA: glynn | ./grass6/lib/gis/color_rule_get.c |no
clones | 1 monsters | 0 warnings
grass-qa at proxy.soccerlab.polymtl.ca
Fri Apr 13 20:44:02 EDT 2007
Hello glynn,
ANALYSIS
lib/gis/color_rule_get.c functions
G_colors_count (Begins at: 9 Ends at: 42)
Complexity: | 5 | | OK |
ParamNBR: | 1 | | OK |
CalledNBR: | 0 | | OK |
LOC: | 34 | | OK |
metrics are OK
G_get_f_color_rule (Begins at: 44 Ends at: 94)
Complexity: | 10 | | OK |
ParamNBR: | 10 | *** | MONSTER |
LOC: | 51 | | OK |
1 metric are OUT OF RANGE!
Clone analysis:
This file does not contain cloned functions
Threshold GRASS6 key metrics values at 2007-04-13 are:
median | upper | outlier |
| quartile | limit |
Complexity (Cyclo): 5 | 25 | 37 |
ParamNBR: 2 | 6 | 9 |
CalledNBR: 10 | 60 | 87 |
LOC: 43 | 195 | 272 |
LOC: Lines Of Code
Message interpretation:
OK : Nothing to say at all
* : above 75 % of value warning
Brought to you by:
