[GRASS-QA] GRASS QA: glynn | ./grass6/lib/gis/color_range.c |no
clones | 0 monsters | 0 warnings
grass-qa at proxy.soccerlab.polymtl.ca
Fri Apr 13 20:44:02 EDT 2007
Hello glynn,
ANALYSIS
lib/gis/color_range.c functions
G_set_color_range (Begins at: 4 Ends at: 18)
Complexity: | 2 | | OK |
ParamNBR: | 3 | | OK |
CalledNBR: | 0 | | OK |
LOC: | 15 | | OK |
metrics are OK
G_set_d_color_range (Begins at: 21 Ends at: 47)
LOC: | 27 | | OK |
metrics are OK
G_get_color_range (Begins at: 50 Ends at: 64)
CalledNBR: | 2 | | OK |
LOC: | 15 | | OK |
metrics are OK
G_get_d_color_range (Begins at: 68 Ends at: 74)
Complexity: | 1 | | OK |
LOC: | 7 | | OK |
metrics are OK
Clone analysis:
This file does not contain cloned functions
Threshold GRASS6 key metrics values at 2007-04-13 are:
median | upper | outlier |
| quartile | limit |
Complexity (Cyclo): 5 | 25 | 37 |
ParamNBR: 2 | 6 | 9 |
CalledNBR: 10 | 60 | 87 |
LOC: 43 | 195 | 272 |
LOC: Lines Of Code
Message interpretation:
OK : Nothing to say at all
* : above 75 % of value warning
Brought to you by:
