[GRASS-QA] GRASS QA: glynn | ./grass6/raster/r.his/his.c |1 clones
( his.c parser.c his.c )| 0 monsters | 1 warnings
grass-qa at proxy.soccerlab.polymtl.ca
Sat Apr 14 18:31:48 EDT 2007
Hello glynn,
ANALYSIS
raster/r.his/his.c functions
HIS_to_RGB (Begins at: 20 Ends at: 59)
Complexity: | 9 | | OK |
ParamNBR: | 8 | ** | Warning |
CalledNBR: | 0 | | OK |
LOC: | 40 | | OK |
at least 1 values are close to an outlier please consider revising code
make_gray_scale (Begins at: 61 Ends at: 71)
Complexity: | 1 | | OK |
ParamNBR: | 1 | | OK |
CalledNBR: | 2 | | OK |
LOC: | 11 | | OK |
metrics are OK
Clone analysis:
This file has 1 potentially cloned functions:
HIS_to_RGB
In raster/r.his/his.c clones of HIS_to_RGB are:
display/d.his/his.c HIS_to_RGB
Threshold GRASS6 key metrics values at 2007-04-14 are:
median | upper | outlier |
| quartile | limit |
Complexity (Cyclo): 5 | 25 | 37 |
ParamNBR: 2 | 6 | 9 |
CalledNBR: 10 | 60 | 87 |
LOC: 43 | 195 | 272 |
LOC: Lines Of Code
Message interpretation:
OK : Nothing to say at all
* : above 75 % of value warning
Brought to you by:
