[GRASS-QA] GRASS QA: glynn | ./grass6/raster/r.mapcalc/map3.c |5
clones ( his.c parser.c his.c map3.c )| 0 monsters | 1 warnings
grass-qa at proxy.soccerlab.polymtl.ca
Sat Apr 14 18:31:48 EDT 2007
Hello glynn,
ANALYSIS
raster/r.mapcalc/map3.c functions
setup_region (Begins at: 19 Ends at: 27)
Complexity: | 1 | | OK |
ParamNBR: | 1 | | OK |
CalledNBR: | 2 | | OK |
LOC: | 9 | | OK |
metrics are OK
handle_to_fd (Begins at: 61 Ends at: 64)
CalledNBR: | 0 | | OK |
LOC: | 4 | | OK |
metrics are OK
fd_to_handle (Begins at: 66 Ends at: 69)
LOC: | 4 | | OK |
metrics are OK
read_row (Begins at: 71 Ends at: 117)
Complexity: | 8 | | OK |
ParamNBR: | 5 | * | |
CalledNBR: | 9 | | OK |
LOC: | 47 | | OK |
metrics are OK
write_row (Begins at: 119 Ends at: 168)
Complexity: | 11 | | OK |
CalledNBR: | 12 | | OK |
LOC: | 50 | | OK |
metrics are OK
compare_ints (Begins at: 172 Ends at: 175)
ParamNBR: | 2 | | OK |
LOC: | 4 | | OK |
metrics are OK
init_colors (Begins at: 177 Ends at: 189)
Complexity: | 6 | | OK |
CalledNBR: | 6 | | OK |
LOC: | 13 | | OK |
metrics are OK
init_cats (Begins at: 191 Ends at: 202)
Complexity: | 3 | | OK |
CalledNBR: | 4 | | OK |
LOC: | 12 | | OK |
metrics are OK
translate_from_colors (Begins at: 204 Ends at: 267)
LOC: | 64 | | OK |
metrics are OK
translate_from_cats (Begins at: 269 Ends at: 325)
ParamNBR: | 4 | | OK |
LOC: | 57 | | OK |
metrics are OK
setup_map (Begins at: 327 Ends at: 329)
LOC: | 3 | | OK |
metrics are OK
read_map (Begins at: 331 Ends at: 368)
ParamNBR: | 6 | * | |
LOC: | 38 | | OK |
metrics are OK
close_map (Begins at: 370 Ends at: 391)
Complexity: | 5 | | OK |
CalledNBR: | 5 | | OK |
LOC: | 22 | | OK |
metrics are OK
map_type (Begins at: 395 Ends at: 434)
Complexity: | 12 | | OK |
CalledNBR: | 8 | | OK |
LOC: | 40 | | OK |
metrics are OK
open_map (Begins at: 436 Ends at: 525)
Complexity: | 25 | * | |
CalledNBR: | 14 | | OK |
LOC: | 90 | | OK |
metrics are OK
setup_maps (Begins at: 527 Ends at: 533)
CalledNBR: | 1 | | OK |
LOC: | 7 | | OK |
metrics are OK
get_map_row (Begins at: 535 Ends at: 567)
Complexity: | 13 | | OK |
ParamNBR: | 7 | ** | Warning |
LOC: | 33 | | OK |
at least 1 values are close to an outlier please consider revising code
close_maps (Begins at: 569 Ends at: 577)
LOC: | 9 | | OK |
metrics are OK
open_output_map (Begins at: 581 Ends at: 598)
Complexity: | 2 | | OK |
CalledNBR: | 3 | | OK |
LOC: | 18 | | OK |
metrics are OK
put_map_row (Begins at: 600 Ends at: 605)
ParamNBR: | 3 | | OK |
LOC: | 6 | | OK |
metrics are OK
close_output_map (Begins at: 607 Ends at: 613)
LOC: | 7 | | OK |
metrics are OK
unopen_output_map (Begins at: 615 Ends at: 618)
LOC: | 4 | | OK |
metrics are OK
copy_cats (Begins at: 622 Ends at: 632)
LOC: | 11 | | OK |
metrics are OK
copy_colors (Begins at: 634 Ends at: 644)
LOC: | 11 | | OK |
metrics are OK
copy_history (Begins at: 646 Ends at: 648)
LOC: | 3 | | OK |
metrics are OK
create_history (Begins at: 650 Ends at: 652)
LOC: | 3 | | OK |
metrics are OK
Clone analysis:
This file has 5 potentially cloned functions:
init_cats translate_from_colors copy_cats translate_from_cats init_colors
In raster/r.mapcalc/map3.c clones of copy_cats are:
raster/r.mapcalc/map.c copy_cats
In raster/r.mapcalc/map3.c clones of init_cats are:
raster/r.mapcalc/map.c init_cats
In raster/r.mapcalc/map3.c clones of init_colors are:
raster/r.mapcalc/map.c init_colors
In raster/r.mapcalc/map3.c clones of translate_from_cats are:
raster/r.mapcalc/map.c translate_from_cats
In raster/r.mapcalc/map3.c clones of translate_from_colors are:
raster/r.mapcalc/map.c translate_from_colors
Threshold GRASS6 key metrics values at 2007-04-14 are:
median | upper | outlier |
| quartile | limit |
Complexity (Cyclo): 5 | 25 | 37 |
ParamNBR: 2 | 6 | 9 |
CalledNBR: 10 | 60 | 87 |
LOC: 43 | 195 | 272 |
LOC: Lines Of Code
Message interpretation:
OK : Nothing to say at all
* : above 75 % of value warning
Brought to you by:
