[GRASS-QA] GRASS QA: glynn | ./grass6/lib/gis/opencell.c |2 clones ( cats.c color_read.c find_cell.c find_vect.c fpreclass.c get_row.c key_value1.c null_val.c opencell.c )| 0 monsters | 1 warnings
Sat Apr 14 19:38:27 EDT 2007
Hello glynn,
ANALYSIS
lib/gis/opencell.c functions
new_fileinfo (Begins at: 113 Ends at: 173)
Complexity:   |       3 |       |      OK |
ParamNBR:     |       1 |       |      OK |
CalledNBR:    |       1 |       |      OK |
LOC:          |      61 |       |      OK |
metrics are OK
G_open_cell_old (Begins at: 177 Ends at: 232)
Complexity:   |       2 |       |      OK |
CalledNBR:    |       4 |       |      OK |
LOC:          |      56 |       |      OK |
metrics are OK
G__open_cell_old (Begins at: 234 Ends at: 434)
Complexity:   |      22 |     * |         |
CalledNBR:    |      42 |     * |         |
LOC:          |     201 |    ** | Warning |
at least 1 values are close to an outlier please consider revising code
G_open_cell_new (Begins at: 460 Ends at: 467)
Complexity:   |       1 |       |      OK |
CalledNBR:    |       2 |       |      OK |
LOC:          |       8 |       |      OK |
metrics are OK
G_open_cell_new_random (Begins at: 469 Ends at: 476)
LOC:          |       8 |       |      OK |
metrics are OK
G_open_cell_new_uncompressed (Begins at: 478 Ends at: 485)
LOC:          |       8 |       |      OK |
metrics are OK
G_want_histogram (Begins at: 487 Ends at: 492)
CalledNBR:    |       0 |       |      OK |
LOC:          |       6 |       |      OK |
metrics are OK
G_set_cell_format (Begins at: 495 Ends at: 508)
Complexity:   |       4 |       |      OK |
LOC:          |      14 |       |      OK |
metrics are OK
G_cellvalue_format (Begins at: 510 Ends at: 518)
LOC:          |       9 |       |      OK |
metrics are OK
G_open_fp_cell_new (Begins at: 520 Ends at: 543)
CalledNBR:    |       3 |       |      OK |
LOC:          |      24 |       |      OK |
metrics are OK
G_open_fp_cell_new_uncompressed (Begins at: 546 Ends at: 567)
LOC:          |      22 |       |      OK |
metrics are OK
clean_check_raster_name (Begins at: 570 Ends at: 602)
ParamNBR:     |       3 |       |      OK |
CalledNBR:    |      11 |       |      OK |
LOC:          |      33 |       |      OK |
metrics are OK
G__open_raster_new (Begins at: 605 Ends at: 776)
Complexity:   |      17 |     * |         |
CalledNBR:    |      52 |     * |         |
LOC:          |     172 |     * |         |
metrics are OK
allocate_compress_buf (Begins at: 784 Ends at: 799)
LOC:          |      16 |       |      OK |
metrics are OK
G__reallocate_work_buf (Begins at: 803 Ends at: 817)
LOC:          |      15 |       |      OK |
metrics are OK
G__reallocate_null_buf (Begins at: 823 Ends at: 837)
LOC:          |      15 |       |      OK |
metrics are OK
G__reallocate_mask_buf (Begins at: 842 Ends at: 856)
LOC:          |      15 |       |      OK |
metrics are OK
G__reallocate_temp_buf (Begins at: 861 Ends at: 888)
LOC:          |      28 |       |      OK |
metrics are OK
G_set_fp_type (Begins at: 890 Ends at: 919)
LOC:          |      30 |       |      OK |
metrics are OK
G_raster_map_is_fp (Begins at: 921 Ends at: 953)
CalledNBR:    |       7 |       |      OK |
LOC:          |      33 |       |      OK |
metrics are OK
G_raster_map_type (Begins at: 955 Ends at: 974)
LOC:          |      20 |       |      OK |
metrics are OK
G_raster_map_type2 (Begins at: 976 Ends at: 1006)
CalledNBR:    |       8 |       |      OK |
LOC:          |      31 |       |      OK |
metrics are OK
G_get_raster_map_type (Begins at: 1008 Ends at: 1012)
LOC:          |       5 |       |      OK |
metrics are OK
G__check_fp_type (Begins at: 1016 Ends at: 1071)
Complexity:   |       8 |       |      OK |
CalledNBR:    |      21 |       |      OK |
LOC:          |      56 |       |      OK |
metrics are OK
G_open_raster_new (Begins at: 1073 Ends at: 1089)
CalledNBR:    |       5 |       |      OK |
LOC:          |      17 |       |      OK |
metrics are OK
G_open_raster_new_uncompressed (Begins at: 1091 Ends at: 1120)
CalledNBR:    |       6 |       |      OK |
LOC:          |      30 |       |      OK |
metrics are OK
G_set_quant_rules (Begins at: 1122 Ends at: 1149)
Complexity:   |       5 |       |      OK |
LOC:          |      28 |       |      OK |
metrics are OK
Clone analysis:
This file has 2 potentially cloned functions:
  G_raster_map_type2  G_raster_map_type
In lib/gis/opencell.c clones of  G_raster_map_type2 are:
	lib/gis/opencell.c  G_raster_map_type
In lib/gis/opencell.c clones of  G_raster_map_type are:
	lib/gis/opencell.c  G_raster_map_type2
Threshold GRASS6 key metrics values at 2007-04-14 are:
                           | quartile  | limit   |
ParamNBR:                2 |         6 |       9 |
CalledNBR:              10 |        60 |      87 |
LOC:                    43 |       195 |     272 |
 LOC: Lines Of Code
Message interpretation:
 OK : Nothing to say at all
Brought to you by:
