[GRASS-QA] GRASS QA: glynn | ./grass6/lib/gis/rm_colr.c |1 clones ( cats.c color_read.c find_cell.c find_vect.c fpreclass.c get_row.c key_value1.c null_val.c opencell.c put_row.c quant.c quant_rw.c range.c rm_colr.c )| 0 monsters | 0 warnings
Sat Apr 14 19:38:28 EDT 2007
Hello glynn,
ANALYSIS
lib/gis/rm_colr.c functions
G_remove_colr (Begins at: 13 Ends at: 21)
Complexity:   |       1 |       |      OK |
ParamNBR:     |       1 |       |      OK |
CalledNBR:    |       4 |       |      OK |
LOC:          |       9 |       |      OK |
metrics are OK
Clone analysis:
This file has 1 potentially cloned functions:
  G_remove_colr
In lib/gis/rm_colr.c clones of  G_remove_colr are:
	lib/gis/parser.c  interactive_flag
Threshold GRASS6 key metrics values at 2007-04-14 are:
                           | quartile  | limit   |
ParamNBR:                2 |         6 |       9 |
CalledNBR:              10 |        60 |      87 |
LOC:                    43 |       195 |     272 |
 LOC: Lines Of Code
Message interpretation:
 OK : Nothing to say at all
Brought to you by:
