[GRASS-QA] GRASS QA: glynn | ./grass6/lib/gis/sample.c |no clones |
0 monsters | 4 warnings
grass-qa at proxy.soccerlab.polymtl.ca
Sat Apr 14 19:38:29 EDT 2007
Hello glynn,
ANALYSIS
lib/gis/sample.c functions
G_get_raster_sample (Begins at: 54 Ends at: 78)
Complexity: | 6 | | OK |
ParamNBR: | 7 | ** | Warning |
CalledNBR: | 5 | | OK |
LOC: | 25 | | OK |
at least 1 values are close to an outlier please consider revising code
raster_sample_nearest (Begins at: 81 Ends at: 116)
Complexity: | 4 | | OK |
ParamNBR: | 6 | * | |
CalledNBR: | 10 | | OK |
LOC: | 36 | | OK |
metrics are OK
raster_sample_bilinear (Begins at: 119 Ends at: 248)
Complexity: | 18 | * | |
CalledNBR: | 47 | * | |
LOC: | 130 | * | |
metrics are OK
raster_sample_cubic (Begins at: 251 Ends at: 457)
Complexity: | 36 | *** | MONSTER |
CalledNBR: | 81 | ** | Warning |
LOC: | 207 | ** | Warning |
at least 3 values are close to an outlier please consider revising code
scancatlabel (Begins at: 460 Ends at: 473)
Complexity: | 2 | | OK |
ParamNBR: | 1 | | OK |
CalledNBR: | 4 | | OK |
LOC: | 14 | | OK |
metrics are OK
raster_row_error (Begins at: 476 Ends at: 483)
Complexity: | 1 | | OK |
ParamNBR: | 3 | | OK |
LOC: | 8 | | OK |
metrics are OK
Clone analysis:
This file does not contain cloned functions
Threshold GRASS6 key metrics values at 2007-04-14 are:
median | upper | outlier |
| quartile | limit |
Complexity (Cyclo): 5 | 25 | 37 |
ParamNBR: 2 | 6 | 9 |
CalledNBR: 10 | 60 | 87 |
LOC: 43 | 195 | 272 |
LOC: Lines Of Code
Message interpretation:
OK : Nothing to say at all
* : above 75 % of value warning
Brought to you by:
