[GRASS-QA] GRASS QA: glynn | ./grass6/lib/gis/flate.c |no clones |
0 monsters | 0 warnings
grass-qa at proxy.soccerlab.polymtl.ca
Sat Apr 14 19:38:23 EDT 2007
Hello glynn,
ANALYSIS
lib/gis/flate.c functions
_init_zstruct (Begins at: 132 Ends at: 141)
Complexity: | 1 | | OK |
ParamNBR: | 1 | | OK |
CalledNBR: | 0 | | OK |
LOC: | 10 | | OK |
metrics are OK
G_zlib_read (Begins at: 144 Ends at: 204)
Complexity: | 8 | | OK |
ParamNBR: | 4 | | OK |
CalledNBR: | 7 | | OK |
LOC: | 61 | | OK |
metrics are OK
G_zlib_write (Begins at: 208 Ends at: 278)
Complexity: | 11 | | OK |
ParamNBR: | 3 | | OK |
CalledNBR: | 9 | | OK |
LOC: | 71 | | OK |
metrics are OK
G_zlib_write_noCompress (Begins at: 282 Ends at: 314)
Complexity: | 6 | | OK |
CalledNBR: | 2 | | OK |
LOC: | 33 | | OK |
metrics are OK
G_zlib_compress (Begins at: 318 Ends at: 394)
Complexity: | 10 | | OK |
CalledNBR: | 12 | | OK |
LOC: | 77 | | OK |
metrics are OK
G_zlib_expand (Begins at: 397 Ends at: 453)
CalledNBR: | 5 | | OK |
LOC: | 57 | | OK |
metrics are OK
Clone analysis:
This file does not contain cloned functions
Threshold GRASS6 key metrics values at 2007-04-14 are:
median | upper | outlier |
| quartile | limit |
Complexity (Cyclo): 5 | 25 | 37 |
ParamNBR: 2 | 6 | 9 |
CalledNBR: 10 | 60 | 87 |
LOC: 43 | 195 | 272 |
LOC: Lines Of Code
Message interpretation:
OK : Nothing to say at all
* : above 75 % of value warning
Brought to you by:
