[GRASS-QA] GRASS QA: glynn | ./grass6/lib/gis/fpreclass.c |13
clones ( cats.c color_read.c find_cell.c find_vect.c
fpreclass.c )| 0 monsters | 0 warnings
grass-qa at proxy.soccerlab.polymtl.ca
Sat Apr 14 19:38:23 EDT 2007
Hello glynn,
ANALYSIS
lib/gis/fpreclass.c functions
G_fpreclass_clear (Begins at: 263 Ends at: 270)
Complexity: | 1 | | OK |
ParamNBR: | 1 | | OK |
CalledNBR: | 0 | | OK |
LOC: | 8 | | OK |
metrics are OK
G_fpreclass_reset (Begins at: 275 Ends at: 283)
Complexity: | 2 | | OK |
CalledNBR: | 2 | | OK |
LOC: | 9 | | OK |
metrics are OK
G_fpreclass_init (Begins at: 287 Ends at: 294)
CalledNBR: | 1 | | OK |
LOC: | 8 | | OK |
metrics are OK
G_fpreclass_set_domain (Begins at: 299 Ends at: 305)
ParamNBR: | 3 | | OK |
LOC: | 7 | | OK |
metrics are OK
G_fpreclass_set_range (Begins at: 310 Ends at: 316)
LOC: | 7 | | OK |
metrics are OK
fpreclass_set_limits (Begins at: 321 Ends at: 328)
ParamNBR: | 5 | * | |
LOC: | 8 | | OK |
metrics are OK
fpreclass_update_limits (Begins at: 333 Ends at: 345)
LOC: | 13 | | OK |
metrics are OK
G_fpreclass_get_limits (Begins at: 350 Ends at: 371)
Complexity: | 4 | | OK |
LOC: | 22 | | OK |
metrics are OK
G_fpreclass_nof_rules (Begins at: 376 Ends at: 380)
LOC: | 5 | | OK |
metrics are OK
G_fpreclass_get_ith_rule (Begins at: 385 Ends at: 392)
ParamNBR: | 6 | * | |
LOC: | 8 | | OK |
metrics are OK
fpreclass_table_increase (Begins at: 397 Ends at: 411)
Complexity: | 3 | | OK |
LOC: | 15 | | OK |
metrics are OK
G_fpreclass_set_neg_infinite_rule (Begins at: 416 Ends at: 423)
LOC: | 8 | | OK |
metrics are OK
G_fpreclass_get_neg_infinite_rule (Begins at: 428 Ends at: 437)
LOC: | 10 | | OK |
metrics are OK
G_fpreclass_set_pos_infinite_rule (Begins at: 442 Ends at: 449)
LOC: | 8 | | OK |
metrics are OK
G_fpreclass_get_pos_infinite_rule (Begins at: 454 Ends at: 463)
LOC: | 10 | | OK |
metrics are OK
G_fpreclass_add_rule (Begins at: 468 Ends at: 488)
LOC: | 21 | | OK |
metrics are OK
G_fpreclass_reverse_rule_order (Begins at: 493 Ends at: 514)
LOC: | 22 | | OK |
metrics are OK
fpreclass_interpolate (Begins at: 519 Ends at: 526)
LOC: | 8 | | OK |
metrics are OK
fpreclass_get_default_cell_value (Begins at: 531 Ends at: 546)
ParamNBR: | 2 | | OK |
CalledNBR: | 3 | | OK |
LOC: | 16 | | OK |
metrics are OK
G_fpreclass_get_cell_value (Begins at: 551 Ends at: 577)
Complexity: | 7 | | OK |
LOC: | 27 | | OK |
metrics are OK
G_fpreclass_perform_di (Begins at: 582 Ends at: 592)
ParamNBR: | 4 | | OK |
LOC: | 11 | | OK |
metrics are OK
G_fpreclass_perform_df (Begins at: 597 Ends at: 607)
LOC: | 11 | | OK |
metrics are OK
G_fpreclass_perform_dd (Begins at: 612 Ends at: 622)
LOC: | 11 | | OK |
metrics are OK
G_fpreclass_perform_fi (Begins at: 627 Ends at: 637)
LOC: | 11 | | OK |
metrics are OK
G_fpreclass_perform_ff (Begins at: 642 Ends at: 652)
LOC: | 11 | | OK |
metrics are OK
G_fpreclass_perform_fd (Begins at: 657 Ends at: 667)
LOC: | 11 | | OK |
metrics are OK
G_fpreclass_perform_ii (Begins at: 672 Ends at: 682)
LOC: | 11 | | OK |
metrics are OK
G_fpreclass_perform_if (Begins at: 687 Ends at: 697)
LOC: | 11 | | OK |
metrics are OK
G_fpreclass_perform_id (Begins at: 702 Ends at: 712)
LOC: | 11 | | OK |
metrics are OK
Clone analysis:
This file has 13 potentially cloned functions:
G_fpreclass_set_pos_infinite_rule G_fpreclass_set_neg_infinite_rule G_fpreclass_get_pos_infinite_rule G_fpreclass_get_neg_infinite_rule G_fpreclass_perform_id G_fpreclass_perform_if G_fpreclass_perform_ii G_fpreclass_perform_fd G_fpreclass_perform_ff G_fpreclass_perform_fi G_fpreclass_perform_dd G_fpreclass_perform_df G_fpreclass_perform_di
In lib/gis/fpreclass.c clones of G_fpreclass_perform_di are:
lib/gis/fpreclass.c G_fpreclass_perform_id
lib/gis/fpreclass.c G_fpreclass_perform_if
lib/gis/fpreclass.c G_fpreclass_perform_ii
lib/gis/fpreclass.c G_fpreclass_perform_fd
lib/gis/fpreclass.c G_fpreclass_perform_ff
lib/gis/fpreclass.c G_fpreclass_perform_fi
lib/gis/fpreclass.c G_fpreclass_perform_dd
lib/gis/fpreclass.c G_fpreclass_perform_df
In lib/gis/fpreclass.c clones of G_fpreclass_set_neg_infinite_rule are:
lib/gis/fpreclass.c G_fpreclass_set_pos_infinite_rule
In lib/gis/fpreclass.c clones of G_fpreclass_perform_df are:
lib/gis/fpreclass.c G_fpreclass_perform_di
In lib/gis/fpreclass.c clones of G_fpreclass_perform_ff are:
In lib/gis/fpreclass.c clones of G_fpreclass_perform_id are:
In lib/gis/fpreclass.c clones of G_fpreclass_set_pos_infinite_rule are:
lib/gis/fpreclass.c G_fpreclass_set_neg_infinite_rule
In lib/gis/fpreclass.c clones of G_fpreclass_get_neg_infinite_rule are:
lib/gis/fpreclass.c G_fpreclass_get_pos_infinite_rule
In lib/gis/fpreclass.c clones of G_fpreclass_perform_ii are:
In lib/gis/fpreclass.c clones of G_fpreclass_perform_dd are:
In lib/gis/fpreclass.c clones of G_fpreclass_get_pos_infinite_rule are:
lib/gis/fpreclass.c G_fpreclass_get_neg_infinite_rule
In lib/gis/fpreclass.c clones of G_fpreclass_perform_if are:
In lib/gis/fpreclass.c clones of G_fpreclass_perform_fi are:
In lib/gis/fpreclass.c clones of G_fpreclass_perform_fd are:
Threshold GRASS6 key metrics values at 2007-04-14 are:
median | upper | outlier |
| quartile | limit |
Complexity (Cyclo): 5 | 25 | 37 |
ParamNBR: 2 | 6 | 9 |
CalledNBR: 10 | 60 | 87 |
LOC: 43 | 195 | 272 |
LOC: Lines Of Code
Message interpretation:
OK : Nothing to say at all
* : above 75 % of value warning
Brought to you by:
