[GRASS-QA] GRASS QA: glynn | ./grass6/lib/gis/mapset_msc.c |no clones | 0 monsters | 0 warnings
Sat Apr 14 19:38:26 EDT 2007
Hello glynn,
ANALYSIS
lib/gis/mapset_msc.c functions
G__make_mapset_element (Begins at: 19 Ends at: 62)
Complexity:   |       9 |       |      OK |
ParamNBR:     |       1 |       |      OK |
CalledNBR:    |       7 |       |      OK |
LOC:          |      44 |       |      OK |
metrics are OK
G__mapset_permissions (Begins at: 64 Ends at: 93)
Complexity:   |       5 |       |      OK |
CalledNBR:    |       4 |       |      OK |
LOC:          |      30 |       |      OK |
metrics are OK
G__mapset_permissions2 (Begins at: 95 Ends at: 115)
ParamNBR:     |       3 |       |      OK |
LOC:          |      21 |       |      OK |
metrics are OK
Clone analysis:
Threshold GRASS6 key metrics values at 2007-04-14 are:
                           | quartile  | limit   |
ParamNBR:                2 |         6 |       9 |
CalledNBR:              10 |        60 |      87 |
LOC:                    43 |       195 |     272 |
 LOC: Lines Of Code
Message interpretation:
 OK : Nothing to say at all
Brought to you by:
