[GRASS-QA] GRASS QA: glynn | ./grass6/lib/gis/mapset_nme.c |no
clones | 0 monsters | 0 warnings
grass-qa at proxy.soccerlab.polymtl.ca
Sat Apr 14 19:38:26 EDT 2007
Hello glynn,
ANALYSIS
lib/gis/mapset_nme.c functions
G__mapset_name (Begins at: 32 Ends at: 47)
Complexity: | 3 | | OK |
ParamNBR: | 1 | | OK |
CalledNBR: | 1 | | OK |
LOC: | 16 | | OK |
metrics are OK
get_list_of_mapsets (Begins at: 49 Ends at: 83)
Complexity: | 6 | | OK |
CalledNBR: | 11 | | OK |
LOC: | 35 | | OK |
metrics are OK
new_mapset (Begins at: 85 Ends at: 96)
Complexity: | 1 | | OK |
CalledNBR: | 2 | | OK |
LOC: | 12 | | OK |
metrics are OK
G__create_alt_search_path (Begins at: 99 Ends at: 108)
LOC: | 10 | | OK |
metrics are OK
G__switch_search_path (Begins at: 110 Ends at: 125)
CalledNBR: | 0 | | OK |
LOC: | 16 | | OK |
metrics are OK
G_reset_mapsets (Begins at: 127 Ends at: 132)
LOC: | 6 | | OK |
metrics are OK
G_available_mapsets (Begins at: 136 Ends at: 184)
Complexity: | 7 | | OK |
CalledNBR: | 14 | | OK |
LOC: | 49 | | OK |
metrics are OK
G_add_mapset_to_search_path (Begins at: 190 Ends at: 198)
Complexity: | 2 | | OK |
LOC: | 9 | | OK |
metrics are OK
Clone analysis:
This file does not contain cloned functions
Threshold GRASS6 key metrics values at 2007-04-14 are:
median | upper | outlier |
| quartile | limit |
Complexity (Cyclo): 5 | 25 | 37 |
ParamNBR: 2 | 6 | 9 |
CalledNBR: 10 | 60 | 87 |
LOC: 43 | 195 | 272 |
LOC: Lines Of Code
Message interpretation:
OK : Nothing to say at all
* : above 75 % of value warning
Brought to you by:
