[GRASS-QA] GRASS QA: glynn | ./grass6/raster/r.in.gdal/main.c |no
clones | 4 monsters | 0 warnings
grass-qa at proxy.soccerlab.polymtl.ca
Sat Apr 14 19:38:30 EDT 2007
Hello glynn,
ANALYSIS
raster/r.in.gdal/main.c functions
main (Begins at: 40 Ends at: 547)
Complexity: | 45 | *** | MONSTER |
ParamNBR: | 2 | | OK |
CalledNBR: | 164 | *** | MONSTER |
LOC: | 508 | *** | MONSTER |
3 metric are OUT OF RANGE!
SetupReprojector (Begins at: 553 Ends at: 606)
Complexity: | 6 | | OK |
ParamNBR: | 4 | | OK |
CalledNBR: | 20 | | OK |
LOC: | 54 | | OK |
metrics are OK
ImportBand (Begins at: 613 Ends at: 918)
Complexity: | 34 | ** | Warning |
ParamNBR: | 5 | * | |
CalledNBR: | 84 | ** | Warning |
LOC: | 306 | *** | MONSTER |
1 metric are OUT OF RANGE!
Clone analysis:
This file does not contain cloned functions
Threshold GRASS6 key metrics values at 2007-04-14 are:
median | upper | outlier |
| quartile | limit |
Complexity (Cyclo): 5 | 25 | 37 |
ParamNBR: 2 | 6 | 9 |
CalledNBR: 10 | 60 | 87 |
LOC: 43 | 195 | 272 |
LOC: Lines Of Code
Message interpretation:
OK : Nothing to say at all
* : above 75 % of value warning
Brought to you by:
