[GRASS-QA] GRASS QA: glynn | ./grass6/db/drivers/dbf/table.c |no
clones | 0 monsters | 0 warnings
grass-qa at proxy.soccerlab.polymtl.ca
Sun Apr 15 15:46:47 EDT 2007
Hello glynn,
ANALYSIS
db/drivers/dbf/table.c functions
add_table (Begins at: 40 Ends at: 68)
Complexity: | 2 | | OK |
ParamNBR: | 2 | | OK |
CalledNBR: | 4 | | OK |
LOC: | 29 | | OK |
metrics are OK
find_table (Begins at: 72 Ends at: 85)
ParamNBR: | 1 | | OK |
CalledNBR: | 3 | | OK |
LOC: | 14 | | OK |
metrics are OK
load_table_head (Begins at: 88 Ends at: 150)
Complexity: | 11 | | OK |
CalledNBR: | 13 | | OK |
LOC: | 63 | | OK |
metrics are OK
load_table (Begins at: 153 Ends at: 217)
Complexity: | 8 | | OK |
LOC: | 65 | | OK |
metrics are OK
save_table (Begins at: 220 Ends at: 318)
Complexity: | 15 | | OK |
CalledNBR: | 19 | | OK |
LOC: | 99 | | OK |
metrics are OK
free_table (Begins at: 320 Ends at: 339)
LOC: | 20 | | OK |
metrics are OK
Clone analysis:
This file does not contain cloned functions
Threshold GRASS6 key metrics values at 2007-04-15 are:
median | upper | outlier |
| quartile | limit |
Complexity (Cyclo): 5 | 25 | 37 |
ParamNBR: 2 | 6 | 9 |
CalledNBR: 10 | 60 | 87 |
LOC: 43 | 195 | 272 |
LOC: Lines Of Code
Message interpretation:
OK : Nothing to say at all
* : above 75 % of value warning
Brought to you by:
