[GRASS-QA] GRASS QA: glynn | ./grass6/lib/vector/Vlib/read_ogr.c
|no clones | 0 monsters | 0 warnings
grass-qa at proxy.soccerlab.polymtl.ca
Sun Apr 15 17:07:53 EDT 2007
Hello glynn,
ANALYSIS
lib/vector/Vlib/read_ogr.c functions
cache_feature (Begins at: 37 Ends at: 132)
Complexity: | 13 | | OK |
ParamNBR: | 3 | | OK |
CalledNBR: | 23 | | OK |
LOC: | 96 | | OK |
metrics are OK
V1_read_next_line_ogr (Begins at: 135 Ends at: 225)
Complexity: | 15 | | OK |
CalledNBR: | 19 | | OK |
LOC: | 91 | | OK |
metrics are OK
V2_read_next_line_ogr (Begins at: 228 Ends at: 246)
Complexity: | 2 | | OK |
CalledNBR: | 1 | | OK |
LOC: | 19 | | OK |
metrics are OK
read_line (Begins at: 248 Ends at: 307)
Complexity: | 10 | | OK |
ParamNBR: | 4 | | OK |
LOC: | 60 | | OK |
metrics are OK
V2_read_line_ogr (Begins at: 310 Ends at: 380)
Complexity: | 12 | | OK |
CalledNBR: | 16 | | OK |
LOC: | 71 | | OK |
metrics are OK
Clone analysis:
This file does not contain cloned functions
Threshold GRASS6 key metrics values at 2007-04-15 are:
median | upper | outlier |
| quartile | limit |
Complexity (Cyclo): 5 | 25 | 37 |
ParamNBR: 2 | 6 | 9 |
CalledNBR: 10 | 60 | 87 |
LOC: 43 | 195 | 272 |
LOC: Lines Of Code
Message interpretation:
OK : Nothing to say at all
* : above 75 % of value warning
Brought to you by:
