[GRASS-QA] GRASS QA: glynn | ./grass6/lib/vector/Vlib/select.c |no
clones | 0 monsters | 0 warnings
grass-qa at proxy.soccerlab.polymtl.ca
Sun Apr 15 17:07:53 EDT 2007
Hello glynn,
ANALYSIS
lib/vector/Vlib/select.c functions
Vect_select_lines_by_box (Begins at: 33 Ends at: 78)
Complexity: | 5 | | OK |
ParamNBR: | 4 | | OK |
CalledNBR: | 9 | | OK |
LOC: | 46 | | OK |
metrics are OK
Vect_select_areas_by_box (Begins at: 81 Ends at: 112)
Complexity: | 2 | | OK |
ParamNBR: | 3 | | OK |
CalledNBR: | 7 | | OK |
LOC: | 32 | | OK |
metrics are OK
Vect_select_isles_by_box (Begins at: 115 Ends at: 138)
CalledNBR: | 6 | | OK |
LOC: | 24 | | OK |
metrics are OK
Vect_select_nodes_by_box (Begins at: 141 Ends at: 175)
LOC: | 35 | | OK |
metrics are OK
Vect_select_lines_by_polygon (Begins at: 178 Ends at: 265)
Complexity: | 10 | | OK |
ParamNBR: | 6 | * | |
CalledNBR: | 15 | | OK |
LOC: | 88 | | OK |
metrics are OK
Vect_select_areas_by_polygon (Begins at: 268 Ends at: 317)
Complexity: | 9 | | OK |
ParamNBR: | 5 | * | |
CalledNBR: | 18 | | OK |
LOC: | 50 | | OK |
metrics are OK
Clone analysis:
This file does not contain cloned functions
Threshold GRASS6 key metrics values at 2007-04-15 are:
median | upper | outlier |
| quartile | limit |
Complexity (Cyclo): 5 | 25 | 37 |
ParamNBR: 2 | 6 | 9 |
CalledNBR: 10 | 60 | 87 |
LOC: 43 | 195 | 272 |
LOC: Lines Of Code
Message interpretation:
OK : Nothing to say at all
* : above 75 % of value warning
Brought to you by:
