[GRASS-QA] GRASS QA: glynn | ./grass6/lib/vector/diglib/spindex_rw.c |no clones | 0 monsters | 0 warnings
Sun Apr 15 17:07:52 EDT 2007
Hello glynn,
ANALYSIS
lib/vector/diglib/spindex_rw.c functions
dig_Wr_spindx_head (Begins at: 26 Ends at: 68)
Complexity:   |      12 |       |      OK |
CalledNBR:    |      16 |       |      OK |
LOC:          |      43 |       |      OK |
metrics are OK
dig_Rd_spindx_head (Begins at: 72 Ends at: 140)
Complexity:   |      14 |       |      OK |
CalledNBR:    |      22 |       |      OK |
LOC:          |      69 |       |      OK |
metrics are OK
rtree_dump_branch (Begins at: 145 Ends at: 161)
Complexity:   |       3 |       |      OK |
ParamNBR:     |       4 |       |      OK |
CalledNBR:    |       3 |       |      OK |
LOC:          |      17 |       |      OK |
metrics are OK
rtree_dump_node (Begins at: 164 Ends at: 180)
ParamNBR:     |       3 |       |      OK |
LOC:          |      17 |       |      OK |
metrics are OK
rtree_write_branch (Begins at: 185 Ends at: 206)
Complexity:   |       7 |       |      OK |
CalledNBR:    |       5 |       |      OK |
LOC:          |      22 |       |      OK |
metrics are OK
rtree_write_node (Begins at: 209 Ends at: 227)
Complexity:   |       5 |       |      OK |
LOC:          |      19 |       |      OK |
metrics are OK
rtree_read_branch (Begins at: 232 Ends at: 260)
CalledNBR:    |       7 |       |      OK |
LOC:          |      29 |       |      OK |
metrics are OK
rtree_read_node (Begins at: 263 Ends at: 282)
Complexity:   |       4 |       |      OK |
CalledNBR:    |       4 |       |      OK |
LOC:          |      20 |       |      OK |
metrics are OK
dig_write_spidx (Begins at: 286 Ends at: 309)
Complexity:   |       1 |       |      OK |
CalledNBR:    |      13 |       |      OK |
LOC:          |      24 |       |      OK |
metrics are OK
dig_read_spidx (Begins at: 313 Ends at: 337)
LOC:          |      25 |       |      OK |
metrics are OK
dig_dump_spidx (Begins at: 341 Ends at: 357)
CalledNBR:    |       8 |       |      OK |
LOC:          |      17 |       |      OK |
metrics are OK
Clone analysis:
Threshold GRASS6 key metrics values at 2007-04-15 are:
                           | quartile  | limit   |
ParamNBR:                2 |         6 |       9 |
CalledNBR:              10 |        60 |      87 |
LOC:                    43 |       195 |     272 |
 LOC: Lines Of Code
Message interpretation:
 OK : Nothing to say at all
Brought to you by:
