[GRASS-QA] GRASS QA: glynn |
./grass6/lib/vector/diglib/plus_struct.c |no clones | 0
monsters | 4 warnings
grass-qa at proxy.soccerlab.polymtl.ca
Sun Apr 15 17:07:52 EDT 2007
Hello glynn,
ANALYSIS
lib/vector/diglib/plus_struct.c functions
dig_Rd_P_node (Begins at: 52 Ends at: 106)
Complexity: | 13 | | OK |
ParamNBR: | 3 | | OK |
CalledNBR: | 11 | | OK |
LOC: | 55 | | OK |
metrics are OK
dig_Wr_P_node (Begins at: 109 Ends at: 156)
CalledNBR: | 10 | | OK |
LOC: | 48 | | OK |
metrics are OK
dig_Rd_P_line (Begins at: 159 Ends at: 241)
Complexity: | 27 | ** | Warning |
CalledNBR: | 21 | | OK |
LOC: | 83 | | OK |
at least 1 values are close to an outlier please consider revising code
dig_Wr_P_line (Begins at: 244 Ends at: 313)
LOC: | 70 | | OK |
dig_Rd_P_area (Begins at: 316 Ends at: 372)
Complexity: | 18 | * | |
CalledNBR: | 15 | | OK |
LOC: | 57 | | OK |
metrics are OK
dig_Wr_P_area (Begins at: 375 Ends at: 417)
Complexity: | 17 | * | |
CalledNBR: | 12 | | OK |
LOC: | 43 | | OK |
metrics are OK
dig_Rd_P_isle (Begins at: 420 Ends at: 467)
Complexity: | 14 | | OK |
LOC: | 48 | | OK |
metrics are OK
dig_Wr_P_isle (Begins at: 470 Ends at: 507)
LOC: | 38 | | OK |
metrics are OK
dig_Rd_Plus_head (Begins at: 514 Ends at: 606)
Complexity: | 33 | ** | Warning |
ParamNBR: | 2 | | OK |
CalledNBR: | 41 | * | |
LOC: | 93 | | OK |
dig_Wr_Plus_head (Begins at: 609 Ends at: 673)
Complexity: | 31 | ** | Warning |
CalledNBR: | 34 | | OK |
LOC: | 65 | | OK |
Clone analysis:
This file does not contain cloned functions
Threshold GRASS6 key metrics values at 2007-04-15 are:
median | upper | outlier |
| quartile | limit |
Complexity (Cyclo): 5 | 25 | 37 |
ParamNBR: 2 | 6 | 9 |
CalledNBR: 10 | 60 | 87 |
LOC: 43 | 195 | 272 |
LOC: Lines Of Code
Message interpretation:
OK : Nothing to say at all
* : above 75 % of value warning
Brought to you by:
