[GRASS-QA] GRASS QA: glynn | ./grass6/raster/r.li/r.li.padrange/padrange.c |1 clones ( input.c georef.c ask.c fpcompress.c g3derror.c padrange.c )| 6 monsters | 0 warnings
Sun Apr 15 17:07:54 EDT 2007
Hello glynn,
ANALYSIS
raster/r.li/r.li.padrange/padrange.c functions
main (Begins at: 31 Ends at: 53)
Complexity:   |       2 |       |      OK |
CalledNBR:    |      11 |       |      OK |
LOC:          |      23 |       |      OK |
metrics are OK
patchAreaDistributionRANGE (Begins at: 54 Ends at: 98)
Complexity:   |       8 |       |      OK |
ParamNBR:     |       4 |       |      OK |
CalledNBR:    |       6 |       |      OK |
LOC:          |      45 |       |      OK |
metrics are OK
calculate (Begins at: 101 Ends at: 542)
Complexity:   |      56 |   *** | MONSTER |
ParamNBR:     |       3 |       |      OK |
CalledNBR:    |      47 |     * |         |
LOC:          |     442 |   *** | MONSTER |
2 metric are OUT OF RANGE!
calculateD (Begins at: 546 Ends at: 971)
LOC:          |     426 |   *** | MONSTER |
calculateF (Begins at: 975 Ends at: 1405)
LOC:          |     431 |   *** | MONSTER |
Clone analysis:
This file has 1 potentially cloned functions:
  main
In raster/r.li/r.li.padrange/padrange.c clones of  main are:
	raster/r.li/r.li.padsd/padsd.c  main
	raster/r.li/r.li.padcv/padcv.c  main
Threshold GRASS6 key metrics values at 2007-04-15 are:
                           | quartile  | limit   |
ParamNBR:                2 |         6 |       9 |
CalledNBR:              10 |        60 |      87 |
LOC:                    43 |       195 |     272 |
 LOC: Lines Of Code
Message interpretation:
 OK : Nothing to say at all
Brought to you by:
