[GRASS-QA] GRASS QA: glynn | ./grass6/lib/vector/Vlib/net.c |no clones | 6 monsters | 0 warnings
Sun Apr 15 17:07:53 EDT 2007
Hello glynn,
ANALYSIS
lib/vector/Vlib/net.c functions
clipper (Begins at: 26 Ends at: 87)
Complexity:   |       4 |       |      OK |
ParamNBR:     |       4 |       |      OK |
CalledNBR:    |      11 |       |      OK |
LOC:          |      62 |       |      OK |
metrics are OK
Vect_net_build_graph (Begins at: 90 Ends at: 390)
Complexity:   |      46 |   *** | MONSTER |
ParamNBR:     |       9 |   *** | MONSTER |
CalledNBR:    |     122 |   *** | MONSTER |
LOC:          |     301 |   *** | MONSTER |
3 metric are OUT OF RANGE!
Vect_net_shortest_path (Begins at: 394 Ends at: 463)
Complexity:   |      12 |       |      OK |
ParamNBR:     |       5 |     * |         |
LOC:          |      70 |       |      OK |
metrics are OK
Vect_net_get_line_cost (Begins at: 472 Ends at: 505)
Complexity:   |       5 |       |      OK |
CalledNBR:    |       4 |       |      OK |
LOC:          |      34 |       |      OK |
metrics are OK
Vect_net_get_node_cost (Begins at: 512 Ends at: 544)
Complexity:   |       1 |       |      OK |
ParamNBR:     |       3 |       |      OK |
CalledNBR:    |       2 |       |      OK |
LOC:          |      33 |       |      OK |
metrics are OK
Vect_net_nearest_nodes (Begins at: 546 Ends at: 733)
Complexity:   |      39 |   *** | MONSTER |
ParamNBR:     |      14 |   *** | MONSTER |
CalledNBR:    |      39 |     * |         |
LOC:          |     188 |     * |         |
2 metric are OUT OF RANGE!
Vect_net_shortest_path_coor (Begins at: 736 Ends at: 907)
Complexity:   |      29 |    ** | Warning |
ParamNBR:     |      16 |   *** | MONSTER |
CalledNBR:    |      47 |     * |         |
LOC:          |     172 |     * |         |
1 metric are OUT OF RANGE!
Clone analysis:
Threshold GRASS6 key metrics values at 2007-04-15 are:
                           | quartile  | limit   |
ParamNBR:                2 |         6 |       9 |
CalledNBR:              10 |        60 |      87 |
LOC:                    43 |       195 |     272 |
 LOC: Lines Of Code
Message interpretation:
 OK : Nothing to say at all
Brought to you by:
