[GRASS-QA] GRASS QA: glynn | ./grass6/lib/vector/Vlib/graph.c |no clones | 0 monsters | 0 warnings
Sun Apr 15 17:07:53 EDT 2007
Hello glynn,
ANALYSIS
lib/vector/Vlib/graph.c functions
clipper (Begins at: 24 Ends at: 65)
Complexity:   |       4 |       |      OK |
ParamNBR:     |       4 |       |      OK |
CalledNBR:    |      11 |       |      OK |
LOC:          |      42 |       |      OK |
metrics are OK
Vect_graph_init (Begins at: 68 Ends at: 86)
Complexity:   |       2 |       |      OK |
CalledNBR:    |       3 |       |      OK |
LOC:          |      19 |       |      OK |
metrics are OK
Vect_graph_build (Begins at: 89 Ends at: 108)
ParamNBR:     |       1 |       |      OK |
LOC:          |      20 |       |      OK |
metrics are OK
Vect_graph_add_edge (Begins at: 111 Ends at: 131)
ParamNBR:     |       5 |     * |         |
LOC:          |      21 |       |      OK |
metrics are OK
Vect_graph_set_node_costs (Begins at: 134 Ends at: 157)
Complexity:   |       1 |       |      OK |
ParamNBR:     |       3 |       |      OK |
LOC:          |      24 |       |      OK |
metrics are OK
Vect_graph_shortest_path (Begins at: 160 Ends at: 226)
Complexity:   |      12 |       |      OK |
LOC:          |      67 |       |      OK |
metrics are OK
Clone analysis:
Threshold GRASS6 key metrics values at 2007-04-15 are:
                           | quartile  | limit   |
ParamNBR:                2 |         6 |       9 |
CalledNBR:              10 |        60 |      87 |
LOC:                    43 |       195 |     272 |
 LOC: Lines Of Code
Message interpretation:
 OK : Nothing to say at all
Brought to you by:
