[GRASS-QA] GRASS QA: glynn | ./grass6/vector/v.voronoi/sw_heap.c |no clones | 0 monsters | 0 warnings
Sun Apr 15 17:07:56 EDT 2007
Hello glynn,
ANALYSIS
vector/v.voronoi/sw_heap.c functions
PQinsert (Begins at: 6 Ends at: 22)
Complexity:   |       2 |       |      OK |
ParamNBR:     |       3 |       |      OK |
CalledNBR:    |       2 |       |      OK |
LOC:          |      17 |       |      OK |
metrics are OK
PQdelete (Begins at: 25 Ends at: 38)
Complexity:   |       3 |       |      OK |
ParamNBR:     |       1 |       |      OK |
LOC:          |      14 |       |      OK |
metrics are OK
PQbucket (Begins at: 41 Ends at: 50)
Complexity:   |       4 |       |      OK |
CalledNBR:    |       0 |       |      OK |
LOC:          |      10 |       |      OK |
metrics are OK
PQempty (Begins at: 55 Ends at: 58)
Complexity:   |       1 |       |      OK |
LOC:          |       4 |       |      OK |
metrics are OK
PQ_min (Begins at: 62 Ends at: 70)
LOC:          |       9 |       |      OK |
metrics are OK
PQextractmin (Begins at: 73 Ends at: 81)
LOC:          |       9 |       |      OK |
metrics are OK
PQinitialize (Begins at: 85 Ends at: 96)
CalledNBR:    |       1 |       |      OK |
LOC:          |      12 |       |      OK |
metrics are OK
Clone analysis:
Threshold GRASS6 key metrics values at 2007-04-15 are:
                           | quartile  | limit   |
ParamNBR:                2 |         6 |       9 |
CalledNBR:              10 |        60 |      87 |
LOC:                    43 |       195 |     272 |
 LOC: Lines Of Code
Message interpretation:
 OK : Nothing to say at all
Brought to you by:
