[GRASS-QA] GRASS QA: glynn | ./grass6/vector/v.voronoi/sw_main.c
|no clones | 0 monsters | 0 warnings
grass-qa at proxy.soccerlab.polymtl.ca
Sun Apr 15 17:07:56 EDT 2007
Hello glynn,
ANALYSIS
vector/v.voronoi/sw_main.c functions
scomp (Begins at: 11 Ends at: 20)
Complexity: | 5 | | OK |
ParamNBR: | 2 | | OK |
CalledNBR: | 0 | | OK |
LOC: | 10 | | OK |
metrics are OK
nextone (Begins at: 24 Ends at: 34)
Complexity: | 2 | | OK |
ParamNBR: | 1 | | OK |
LOC: | 11 | | OK |
metrics are OK
removeDuplicates (Begins at: 37 Ends at: 59)
ParamNBR: | 0 | | OK |
CalledNBR: | 1 | | OK |
LOC: | 23 | | OK |
metrics are OK
readsites (Begins at: 63 Ends at: 107)
Complexity: | 7 | | OK |
CalledNBR: | 8 | | OK |
LOC: | 45 | | OK |
metrics are OK
readone (Begins at: 111 Ends at: 124)
CalledNBR: | 2 | | OK |
LOC: | 14 | | OK |
metrics are OK
Clone analysis:
This file does not contain cloned functions
Threshold GRASS6 key metrics values at 2007-04-15 are:
median | upper | outlier |
| quartile | limit |
Complexity (Cyclo): 5 | 25 | 37 |
ParamNBR: 2 | 6 | 9 |
CalledNBR: 10 | 60 | 87 |
LOC: 43 | 195 | 272 |
LOC: Lines Of Code
Message interpretation:
OK : Nothing to say at all
* : above 75 % of value warning
Brought to you by:
