[GRASS-QA] GRASS QA: glynn |
./grass6/raster/r.le/r.le.pixel/driver.c |no clones | 5
monsters | 2 warnings
grass-qa at proxy.soccerlab.polymtl.ca
Sun Apr 15 17:07:53 EDT 2007
Hello glynn,
ANALYSIS
raster/r.le/r.le.pixel/driver.c functions
texture_fore (Begins at: 47 Ends at: 140)
Complexity: | 13 | | OK |
ParamNBR: | 0 | | OK |
CalledNBR: | 41 | * | |
LOC: | 94 | | OK |
metrics are OK
mv_driver (Begins at: 147 Ends at: 1072)
Complexity: | 167 | *** | MONSTER |
CalledNBR: | 356 | *** | MONSTER |
LOC: | 926 | *** | MONSTER |
3 metric are OUT OF RANGE!
set_colors (Begins at: 1074 Ends at: 1091)
Complexity: | 1 | | OK |
ParamNBR: | 1 | | OK |
CalledNBR: | 5 | | OK |
LOC: | 18 | | OK |
metrics are OK
fopen0 (Begins at: 1093 Ends at: 1108)
Complexity: | 2 | | OK |
ParamNBR: | 2 | | OK |
CalledNBR: | 8 | | OK |
LOC: | 16 | | OK |
metrics are OK
fopen1 (Begins at: 1116 Ends at: 1133)
CalledNBR: | 10 | | OK |
LOC: | 18 | | OK |
metrics are OK
fopen2 (Begins at: 1139 Ends at: 1155)
CalledNBR: | 9 | | OK |
LOC: | 17 | | OK |
metrics are OK
fopen3 (Begins at: 1161 Ends at: 1177)
LOC: | 17 | | OK |
metrics are OK
meter2 (Begins at: 1185 Ends at: 1224)
Complexity: | 6 | | OK |
ParamNBR: | 3 | | OK |
LOC: | 40 | | OK |
metrics are OK
read_mwind (Begins at: 1230 Ends at: 1259)
ParamNBR: | 7 | ** | Warning |
CalledNBR: | 12 | | OK |
LOC: | 30 | | OK |
at least 1 values are close to an outlier please consider revising code
unit_driver (Begins at: 1265 Ends at: 1499)
Complexity: | 42 | *** | MONSTER |
CalledNBR: | 69 | ** | Warning |
LOC: | 235 | ** | Warning |
1 metric are OUT OF RANGE!
run_clip (Begins at: 1501 Ends at: 1559)
Complexity: | 5 | | OK |
ParamNBR: | 10 | *** | MONSTER |
LOC: | 59 | | OK |
whole_reg_driver (Begins at: 1561 Ends at: 1752)
Complexity: | 34 | ** | Warning |
CalledNBR: | 35 | | OK |
LOC: | 192 | * | |
get_rich_whole (Begins at: 1754 Ends at: 1779)
Complexity: | 3 | | OK |
CalledNBR: | 0 | | OK |
LOC: | 26 | | OK |
metrics are OK
Clone analysis:
This file does not contain cloned functions
Threshold GRASS6 key metrics values at 2007-04-15 are:
median | upper | outlier |
| quartile | limit |
Complexity (Cyclo): 5 | 25 | 37 |
ParamNBR: 2 | 6 | 9 |
CalledNBR: 10 | 60 | 87 |
LOC: 43 | 195 | 272 |
LOC: Lines Of Code
Message interpretation:
OK : Nothing to say at all
* : above 75 % of value warning
Brought to you by:
