[GRASS-QA] GRASS QA: glynn | ./grass6/display/d.his/main.c |no
	clones | 0 monsters | 3 warnings
    grass-qa at proxy.soccerlab.polymtl.ca
    Sun Apr 15 17:35:28 EDT 2007
Hello glynn,
ANALYSIS
display/d.his/main.c functions
main (Begins at: 11 Ends at: 257)
Complexity:   |      27 |    ** | Warning |
CalledNBR:    |      72 |    ** | Warning |
LOC:          |     247 |    ** | Warning |
at least 3 values are close to an outlier please consider revising code
Clone analysis:
Threshold GRASS6 key metrics values at 2007-04-15 are:
                           | quartile  | limit   |
ParamNBR:                2 |         6 |       9 |
CalledNBR:              10 |        60 |      87 |
LOC:                    43 |       195 |     272 |
 LOC: Lines Of Code
Message interpretation:
 OK : Nothing to say at all
Brought to you by:
