[GRASS-QA] GRASS QA: glynn | ./grass6/display/d.histogram/bar.c |no
clones | 2 monsters | 0 warnings
grass-qa at proxy.soccerlab.polymtl.ca
Sun Apr 15 17:35:28 EDT 2007
Hello glynn,
ANALYSIS
display/d.histogram/bar.c functions
bar (Begins at: 34 Ends at: 446)
Complexity: | 43 | *** | MONSTER |
ParamNBR: | 2 | | OK |
CalledNBR: | 74 | ** | Warning |
LOC: | 413 | *** | MONSTER |
2 metric are OUT OF RANGE!
rem (Begins at: 450 Ends at: 454)
Complexity: | 1 | | OK |
CalledNBR: | 0 | | OK |
LOC: | 5 | | OK |
metrics are OK
Clone analysis:
This file does not contain cloned functions
Threshold GRASS6 key metrics values at 2007-04-15 are:
median | upper | outlier |
| quartile | limit |
Complexity (Cyclo): 5 | 25 | 37 |
ParamNBR: 2 | 6 | 9 |
CalledNBR: 10 | 60 | 87 |
LOC: 43 | 195 | 272 |
LOC: Lines Of Code
Message interpretation:
OK : Nothing to say at all
* : above 75 % of value warning
Brought to you by:
