[GRASS-QA] GRASS QA: glynn | ./grass6/display/d.histogram/pie.c |no clones | 1 monsters | 0 warnings
Sun Apr 15 17:35:28 EDT 2007
Hello glynn,
ANALYSIS
display/d.histogram/pie.c functions
pie (Begins at: 43 Ends at: 394)
Complexity:   |      32 |    ** | Warning |
CalledNBR:    |      62 |    ** | Warning |
LOC:          |     352 |   *** | MONSTER |
1 metric are OUT OF RANGE!
Clone analysis:
Threshold GRASS6 key metrics values at 2007-04-15 are:
                           | quartile  | limit   |
ParamNBR:                2 |         6 |       9 |
CalledNBR:              10 |        60 |      87 |
LOC:                    43 |       195 |     272 |
 LOC: Lines Of Code
Message interpretation:
 OK : Nothing to say at all
Brought to you by:
