[GRASS-QA] GRASS QA: glynn | ./grass6/lib/gis/timestamp.c |3 clones ( orig_wind.c get_row.c range.c timestamp.c )| 0 monsters | 0 warnings
Sun Apr 15 23:22:20 EDT 2007
Hello glynn,
ANALYSIS
lib/gis/timestamp.c functions
G_init_timestamp (Begins at: 99 Ends at: 102)
Complexity:   |       1 |       |      OK |
ParamNBR:     |       1 |       |      OK |
CalledNBR:    |       0 |       |      OK |
LOC:          |       4 |       |      OK |
metrics are OK
G_set_timestamp (Begins at: 104 Ends at: 108)
CalledNBR:    |       1 |       |      OK |
LOC:          |       5 |       |      OK |
metrics are OK
G_set_timestamp_range (Begins at: 110 Ends at: 117)
ParamNBR:     |       3 |       |      OK |
CalledNBR:    |       2 |       |      OK |
LOC:          |       8 |       |      OK |
metrics are OK
G__read_timestamp (Begins at: 119 Ends at: 145)
Complexity:   |       3 |       |      OK |
CalledNBR:    |       3 |       |      OK |
LOC:          |      27 |       |      OK |
metrics are OK
G__write_timestamp (Begins at: 147 Ends at: 171)
Complexity:   |       2 |       |      OK |
LOC:          |      25 |       |      OK |
metrics are OK
G_format_timestamp (Begins at: 173 Ends at: 210)
Complexity:   |       7 |       |      OK |
CalledNBR:    |       4 |       |      OK |
LOC:          |      38 |       |      OK |
metrics are OK
G_scan_timestamp (Begins at: 212 Ends at: 259)
Complexity:   |       6 |       |      OK |
CalledNBR:    |       6 |       |      OK |
LOC:          |      48 |       |      OK |
metrics are OK
G_get_timestamps (Begins at: 261 Ends at: 279)
ParamNBR:     |       4 |       |      OK |
LOC:          |      19 |       |      OK |
metrics are OK
write_timestamp (Begins at: 287 Ends at: 311)
CalledNBR:    |       9 |       |      OK |
LOC:          |      25 |       |      OK |
metrics are OK
read_timestamp (Begins at: 319 Ends at: 362)
Complexity:   |       4 |       |      OK |
ParamNBR:     |       5 |     * |         |
CalledNBR:    |       8 |       |      OK |
LOC:          |      44 |       |      OK |
metrics are OK
G_read_raster_timestamp (Begins at: 364 Ends at: 382)
LOC:          |      19 |       |      OK |
metrics are OK
G_remove_raster_timestamp (Begins at: 384 Ends at: 401)
LOC:          |      18 |       |      OK |
metrics are OK
G_read_vector_timestamp (Begins at: 403 Ends at: 424)
LOC:          |      22 |       |      OK |
metrics are OK
G_remove_vector_timestamp (Begins at: 426 Ends at: 441)
LOC:          |      16 |       |      OK |
metrics are OK
G_read_grid3_timestamp (Begins at: 443 Ends at: 461)
LOC:          |      19 |       |      OK |
metrics are OK
G_remove_grid3_timestamp (Begins at: 463 Ends at: 480)
LOC:          |      18 |       |      OK |
metrics are OK
G_write_raster_timestamp (Begins at: 482 Ends at: 501)
LOC:          |      20 |       |      OK |
metrics are OK
G_write_vector_timestamp (Begins at: 503 Ends at: 521)
LOC:          |      19 |       |      OK |
metrics are OK
G_write_grid3_timestamp (Begins at: 523 Ends at: 528)
LOC:          |       6 |       |      OK |
metrics are OK
Clone analysis:
This file has 3 potentially cloned functions:
  G_remove_vector_timestamp  G_read_grid3_timestamp  G_read_raster_timestamp
In lib/gis/timestamp.c clones of  G_read_raster_timestamp are:
	lib/gis/timestamp.c  G_read_grid3_timestamp
In lib/gis/timestamp.c clones of  G_remove_vector_timestamp are:
	lib/gis/range.c  G__remove_fp_range
In lib/gis/timestamp.c clones of  G_read_grid3_timestamp are:
	lib/gis/timestamp.c  G_read_raster_timestamp
Threshold GRASS6 key metrics values at 2007-04-15 are:
                           | quartile  | limit   |
ParamNBR:                2 |         6 |       9 |
CalledNBR:              10 |        60 |      87 |
LOC:                    43 |       195 |     272 |
 LOC: Lines Of Code
Message interpretation:
 OK : Nothing to say at all
Brought to you by:
