[GRASS-QA] GRASS QA: glynn | ./grass6/raster/r.null/null.c |1
clones ( orig_wind.c get_row.c range.c timestamp.c null.c )|
0 monsters | 0 warnings
grass-qa at proxy.soccerlab.polymtl.ca
Sun Apr 15 23:22:20 EDT 2007
Hello glynn,
ANALYSIS
raster/r.null/null.c functions
main (Begins at: 15 Ends at: 183)
Complexity: | 16 | * | |
ParamNBR: | 2 | | OK |
CalledNBR: | 60 | * | |
LOC: | 169 | * | |
metrics are OK
parse_vallist (Begins at: 185 Ends at: 218)
Complexity: | 6 | | OK |
CalledNBR: | 10 | | OK |
LOC: | 34 | | OK |
metrics are OK
parse_d_mask_rule (Begins at: 221 Ends at: 250)
ParamNBR: | 3 | | OK |
LOC: | 30 | | OK |
metrics are OK
process (Begins at: 253 Ends at: 295)
Complexity: | 7 | | OK |
ParamNBR: | 4 | | OK |
CalledNBR: | 15 | | OK |
LOC: | 43 | | OK |
metrics are OK
doit (Begins at: 298 Ends at: 346)
CalledNBR: | 18 | | OK |
LOC: | 49 | | OK |
metrics are OK
Clone analysis:
This file has 1 potentially cloned functions:
parse_vallist
In raster/r.null/null.c clones of parse_vallist are:
display/d.rast/main.c parse_vallist
display/d.rast/main.c parse_catlist
Threshold GRASS6 key metrics values at 2007-04-15 are:
median | upper | outlier |
| quartile | limit |
Complexity (Cyclo): 5 | 25 | 37 |
ParamNBR: 2 | 6 | 9 |
CalledNBR: 10 | 60 | 87 |
LOC: 43 | 195 | 272 |
LOC: Lines Of Code
Message interpretation:
OK : Nothing to say at all
* : above 75 % of value warning
Brought to you by:
