[GRASS-QA] GRASS QA: glynn | ./grass6/lib/segment/format.c |no
clones | 0 monsters | 1 warnings
grass-qa at proxy.soccerlab.polymtl.ca
Mon Apr 16 16:44:19 EDT 2007
Hello glynn,
ANALYSIS
lib/segment/format.c functions
segment_format (Begins at: 60 Ends at: 97)
Complexity: | 1 | | OK |
ParamNBR: | 6 | * | |
CalledNBR: | 1 | | OK |
LOC: | 38 | | OK |
metrics are OK
segment_format_nofill (Begins at: 99 Ends at: 102)
LOC: | 4 | | OK |
metrics are OK
_segment_format (Begins at: 105 Ends at: 153)
Complexity: | 7 | | OK |
ParamNBR: | 7 | ** | Warning |
CalledNBR: | 11 | | OK |
LOC: | 49 | | OK |
at least 1 values are close to an outlier please consider revising code
write_int (Begins at: 156 Ends at: 167)
Complexity: | 2 | | OK |
ParamNBR: | 2 | | OK |
CalledNBR: | 4 | | OK |
LOC: | 12 | | OK |
metrics are OK
zero_fill (Begins at: 170 Ends at: 217)
Complexity: | 3 | | OK |
CalledNBR: | 9 | | OK |
LOC: | 48 | | OK |
metrics are OK
Clone analysis:
This file does not contain cloned functions
Threshold GRASS6 key metrics values at 2007-04-16 are:
median | upper | outlier |
| quartile | limit |
Complexity (Cyclo): 5 | 25 | 37 |
ParamNBR: 2 | 6 | 9 |
CalledNBR: 10 | 60 | 87 |
LOC: 43 | 195 | 272 |
LOC: Lines Of Code
Message interpretation:
OK : Nothing to say at all
* : above 75 % of value warning
Brought to you by:
