[GRASS-QA] GRASS QA: glynn | ./grass6/imagery/i.rectify/write.c |1
clones ( write.c write.c )| 0 monsters | 0 warnings
grass-qa at proxy.soccerlab.polymtl.ca
Mon Apr 16 16:44:19 EDT 2007
Hello glynn,
ANALYSIS
imagery/i.rectify/write.c functions
write_matrix (Begins at: 7 Ends at: 34)
Complexity: | 3 | | OK |
ParamNBR: | 2 | | OK |
CalledNBR: | 11 | | OK |
LOC: | 28 | | OK |
metrics are OK
write_map (Begins at: 36 Ends at: 67)
Complexity: | 4 | | OK |
ParamNBR: | 1 | | OK |
CalledNBR: | 16 | | OK |
LOC: | 32 | | OK |
metrics are OK
Clone analysis:
This file has 1 potentially cloned functions:
write_map
In imagery/i.rectify/write.c clones of write_map are:
imagery/i.ortho.photo/photo.rectify/write.c write_map
Threshold GRASS6 key metrics values at 2007-04-16 are:
median | upper | outlier |
| quartile | limit |
Complexity (Cyclo): 5 | 25 | 37 |
ParamNBR: 2 | 6 | 9 |
CalledNBR: 10 | 60 | 87 |
LOC: 43 | 195 | 272 |
LOC: Lines Of Code
Message interpretation:
OK : Nothing to say at all
* : above 75 % of value warning
Brought to you by:
