[GRASS-QA] GRASS QA: glynn |
	./grass6/imagery/i.ortho.photo/photo.rectify/write.c |1
	clones ( write.c )| 0 monsters | 0 warnings
    grass-qa at proxy.soccerlab.polymtl.ca
    Mon Apr 16 16:44:19 EDT 2007
Hello glynn,
ANALYSIS
imagery/i.ortho.photo/photo.rectify/write.c functions
write_matrix (Begins at: 9 Ends at: 35)
Complexity:   |       3 |       |      OK |
CalledNBR:    |      13 |       |      OK |
LOC:          |      27 |       |      OK |
metrics are OK
write_map (Begins at: 37 Ends at: 68)
Complexity:   |       4 |       |      OK |
ParamNBR:     |       1 |       |      OK |
CalledNBR:    |      16 |       |      OK |
LOC:          |      32 |       |      OK |
metrics are OK
Clone analysis:
This file has 1 potentially cloned functions:
  write_map
In imagery/i.ortho.photo/photo.rectify/write.c clones of  write_map are:
	imagery/i.rectify/write.c  write_map
Threshold GRASS6 key metrics values at 2007-04-16 are:
                           | quartile  | limit   |
ParamNBR:                2 |         6 |       9 |
CalledNBR:              10 |        60 |      87 |
LOC:                    43 |       195 |     272 |
 LOC: Lines Of Code
Message interpretation:
 OK : Nothing to say at all
Brought to you by:
