[GRASS-QA] GRASS QA: glynn | ./grass6/raster/r.drain/resolve.c |2 clones ( write.c write.c resolve.c )| 0 monsters | 1 warnings
Mon Apr 16 16:44:19 EDT 2007
Hello glynn,
ANALYSIS
raster/r.drain/resolve.c functions
select_dir (Begins at: 6 Ends at: 30)
Complexity:   |       1 |       |      OK |
ParamNBR:     |       1 |       |      OK |
CalledNBR:    |       0 |       |      OK |
LOC:          |      25 |       |      OK |
metrics are OK
flink (Begins at: 32 Ends at: 88)
Complexity:   |      12 |       |      OK |
ParamNBR:     |       9 |   *** | MONSTER |
CalledNBR:    |       2 |       |      OK |
LOC:          |      57 |       |      OK |
at least 1 values are close to an outlier please consider revising code
resolve (Begins at: 90 Ends at: 204)
ParamNBR:     |       3 |       |      OK |
CalledNBR:    |      26 |       |      OK |
LOC:          |     115 |       |      OK |
metrics are OK
Clone analysis:
This file has 2 potentially cloned functions:
  flink  select_dir
In raster/r.drain/resolve.c clones of  select_dir are:
	raster/r.fill.dir/resolve.c  select_dir
In raster/r.drain/resolve.c clones of  flink are:
	raster/r.fill.dir/resolve.c  flink
Threshold GRASS6 key metrics values at 2007-04-16 are:
                           | quartile  | limit   |
ParamNBR:                2 |         6 |       9 |
CalledNBR:              10 |        60 |      87 |
LOC:                    43 |       195 |     272 |
 LOC: Lines Of Code
Message interpretation:
 OK : Nothing to say at all
Brought to you by:
