[GRASS-QA] GRASS QA: glynn | ./grass6/raster/r.compress/main.c |no clones | 0 monsters | 0 warnings
Mon Apr 16 17:39:21 EDT 2007
Hello glynn,
ANALYSIS
raster/r.compress/main.c functions
main (Begins at: 48 Ends at: 99)
Complexity:   |       4 |       |      OK |
CalledNBR:    |      17 |       |      OK |
LOC:          |      52 |       |      OK |
metrics are OK
process (Begins at: 103 Ends at: 183)
Complexity:   |      13 |       |      OK |
CalledNBR:    |      40 |     * |         |
LOC:          |      81 |       |      OK |
metrics are OK
doit (Begins at: 186 Ends at: 264)
Complexity:   |      11 |       |      OK |
ParamNBR:     |       3 |       |      OK |
CalledNBR:    |      31 |       |      OK |
LOC:          |      79 |       |      OK |
metrics are OK
Clone analysis:
Threshold GRASS6 key metrics values at 2007-04-16 are:
                           | quartile  | limit   |
ParamNBR:                2 |         6 |       9 |
CalledNBR:              10 |        60 |      87 |
LOC:                    43 |       195 |     272 |
 LOC: Lines Of Code
Message interpretation:
 OK : Nothing to say at all
Brought to you by:
