[GRASS-QA] GRASS QA: markus | ./grass6/vector/lidar/lidarlib/InterpSpline.c |no clones | 4 monsters | 2 warnings
Mon Apr 16 17:48:29 EDT 2007
Hello markus,
ANALYSIS
vector/lidar/lidarlib/InterpSpline.c functions
node_x (Begins at: 30 Ends at: 36)
Complexity:   |       1 |       |      OK |
ParamNBR:     |       5 |     * |         |
CalledNBR:    |       0 |       |      OK |
LOC:          |       7 |       |      OK |
metrics are OK
node_y (Begins at: 41 Ends at: 47)
LOC:          |       7 |       |      OK |
metrics are OK
order (Begins at: 52 Ends at: 55)
ParamNBR:     |       3 |       |      OK |
LOC:          |       4 |       |      OK |
metrics are OK
phi_3 (Begins at: 60 Ends at: 63)
ParamNBR:     |       1 |       |      OK |
CalledNBR:    |       2 |       |      OK |
LOC:          |       4 |       |      OK |
metrics are OK
phi_4 (Begins at: 65 Ends at: 68)
CalledNBR:    |       1 |       |      OK |
LOC:          |       4 |       |      OK |
metrics are OK
phi_33 (Begins at: 70 Ends at: 73)
LOC:          |       4 |       |      OK |
metrics are OK
phi_34 (Begins at: 75 Ends at: 78)
LOC:          |       4 |       |      OK |
metrics are OK
phi_43 (Begins at: 80 Ends at: 83)
LOC:          |       4 |       |      OK |
metrics are OK
phi_44 (Begins at: 85 Ends at: 88)
LOC:          |       4 |       |      OK |
metrics are OK
phi (Begins at: 90 Ends at: 93)
LOC:          |       4 |       |      OK |
metrics are OK
normalDefBicubic (Begins at: 98 Ends at: 174)
Complexity:   |       5 |       |      OK |
ParamNBR:     |      13 |   *** | MONSTER |
CalledNBR:    |      22 |       |      OK |
LOC:          |      77 |       |      OK |
1 metric are OUT OF RANGE!
nCorrectLapl (Begins at: 180 Ends at: 253)
ParamNBR:     |       6 |     * |         |
CalledNBR:    |       3 |       |      OK |
LOC:          |      74 |       |      OK |
metrics are OK
normalDefBilin (Begins at: 258 Ends at: 354)
CalledNBR:    |      10 |       |      OK |
LOC:          |      97 |       |      OK |
nCorrectGrad (Begins at: 356 Ends at: 384)
Complexity:   |       3 |       |      OK |
LOC:          |      29 |       |      OK |
metrics are OK
obsEstimateBicubic (Begins at: 389 Ends at: 443)
ParamNBR:     |      10 |   *** | MONSTER |
CalledNBR:    |      19 |       |      OK |
LOC:          |      55 |       |      OK |
dataInterpolateBicubic (Begins at: 449 Ends at: 500)
ParamNBR:     |       9 |   *** | MONSTER |
LOC:          |      52 |       |      OK |
at least 1 values are close to an outlier please consider revising code
obsEstimateBilin (Begins at: 506 Ends at: 545)
CalledNBR:    |       7 |       |      OK |
LOC:          |      40 |       |      OK |
dataInterpolateBilin (Begins at: 551 Ends at: 587)
LOC:          |      37 |       |      OK |
Clone analysis:
Threshold GRASS6 key metrics values at 2007-04-16 are:
                           | quartile  | limit   |
ParamNBR:                2 |         6 |       9 |
CalledNBR:              10 |        60 |      87 |
LOC:                    43 |       195 |     272 |
 LOC: Lines Of Code
Message interpretation:
 OK : Nothing to say at all
Brought to you by:
