[GRASS-QA] GRASS QA: glynn | ./grass6/lib/datetime/tz1.c |1 clones ( tz1.c )| 0 monsters | 0 warnings
Thu Apr 19 19:33:40 EDT 2007
Hello glynn,
ANALYSIS
lib/datetime/tz1.c functions
have (Begins at: 10 Ends at: 24)
Complexity:   |       1 |       |      OK |
CalledNBR:    |       1 |       |      OK |
LOC:          |      15 |       |      OK |
metrics are OK
datetime_check_timezone (Begins at: 26 Ends at: 49)
Complexity:   |       4 |       |      OK |
CalledNBR:    |       6 |       |      OK |
LOC:          |      24 |       |      OK |
metrics are OK
datetime_get_timezone (Begins at: 52 Ends at: 72)
Complexity:   |       2 |       |      OK |
LOC:          |      21 |       |      OK |
metrics are OK
datetime_set_timezone (Begins at: 75 Ends at: 94)
LOC:          |      20 |       |      OK |
metrics are OK
datetime_unset_timezone (Begins at: 97 Ends at: 114)
ParamNBR:     |       1 |       |      OK |
CalledNBR:    |       0 |       |      OK |
LOC:          |      18 |       |      OK |
metrics are OK
datetime_is_valid_timezone (Begins at: 117 Ends at: 120)
LOC:          |       4 |       |      OK |
metrics are OK
Clone analysis:
This file has 1 potentially cloned functions:
  have
In lib/datetime/tz1.c clones of  have are:
	lib/gis/cats.c  G_write_cats
Threshold GRASS6 key metrics values at 2007-04-19 are:
                           | quartile  | limit   |
ParamNBR:                2 |         6 |       9 |
CalledNBR:              10 |        60 |      87 |
LOC:                    43 |       195 |     273 |
 LOC: Lines Of Code
Message interpretation:
 OK : Nothing to say at all
Brought to you by:
