[GRASS-QA] GRASS QA: glynn | ./grass6/lib/datetime/values.c |4
clones ( tz1.c values.c )| 0 monsters | 0 warnings
grass-qa at proxy.soccerlab.polymtl.ca
Thu Apr 19 19:33:40 EDT 2007
Hello glynn,
ANALYSIS
lib/datetime/values.c functions
have (Begins at: 10 Ends at: 27)
Complexity: | 1 | | OK |
ParamNBR: | 2 | | OK |
CalledNBR: | 1 | | OK |
LOC: | 18 | | OK |
metrics are OK
datetime_check_year (Begins at: 29 Ends at: 53)
Complexity: | 4 | | OK |
CalledNBR: | 5 | | OK |
LOC: | 25 | | OK |
metrics are OK
datetime_check_month (Begins at: 55 Ends at: 90)
Complexity: | 5 | | OK |
CalledNBR: | 7 | | OK |
LOC: | 36 | | OK |
metrics are OK
datetime_check_day (Begins at: 92 Ends at: 127)
Complexity: | 7 | | OK |
CalledNBR: | 9 | | OK |
LOC: | 36 | | OK |
metrics are OK
datetime_check_hour (Begins at: 129 Ends at: 153)
CalledNBR: | 4 | | OK |
LOC: | 25 | | OK |
metrics are OK
datetime_check_minute (Begins at: 155 Ends at: 179)
LOC: | 25 | | OK |
metrics are OK
datetime_check_second (Begins at: 181 Ends at: 205)
LOC: | 25 | | OK |
metrics are OK
datetime_check_fracsec (Begins at: 207 Ends at: 225)
Complexity: | 3 | | OK |
CalledNBR: | 3 | | OK |
LOC: | 19 | | OK |
metrics are OK
datetime_get_year (Begins at: 227 Ends at: 249)
Complexity: | 2 | | OK |
LOC: | 23 | | OK |
metrics are OK
datetime_set_year (Begins at: 251 Ends at: 275)
CalledNBR: | 2 | | OK |
LOC: | 25 | | OK |
metrics are OK
datetime_get_month (Begins at: 277 Ends at: 299)
LOC: | 23 | | OK |
metrics are OK
datetime_set_month (Begins at: 301 Ends at: 325)
LOC: | 25 | | OK |
metrics are OK
datetime_get_day (Begins at: 327 Ends at: 354)
LOC: | 28 | | OK |
metrics are OK
datetime_set_day (Begins at: 356 Ends at: 376)
LOC: | 21 | | OK |
metrics are OK
datetime_get_hour (Begins at: 378 Ends at: 398)
LOC: | 21 | | OK |
metrics are OK
datetime_set_hour (Begins at: 400 Ends at: 420)
LOC: | 21 | | OK |
metrics are OK
datetime_get_minute (Begins at: 422 Ends at: 442)
LOC: | 21 | | OK |
metrics are OK
datetime_set_minute (Begins at: 444 Ends at: 464)
LOC: | 21 | | OK |
metrics are OK
datetime_get_second (Begins at: 466 Ends at: 486)
LOC: | 21 | | OK |
metrics are OK
datetime_set_second (Begins at: 488 Ends at: 508)
LOC: | 21 | | OK |
metrics are OK
datetime_get_fracsec (Begins at: 510 Ends at: 530)
LOC: | 21 | | OK |
metrics are OK
datetime_set_fracsec (Begins at: 532 Ends at: 541)
LOC: | 10 | | OK |
metrics are OK
Clone analysis:
This file has 4 potentially cloned functions:
datetime_check_minute datetime_check_hour datetime_set_month datetime_set_year
In lib/datetime/values.c clones of datetime_check_minute are:
lib/datetime/values.c datetime_check_hour
In lib/datetime/values.c clones of datetime_set_year are:
lib/datetime/values.c datetime_set_month
In lib/datetime/values.c clones of datetime_set_month are:
lib/datetime/values.c datetime_set_year
In lib/datetime/values.c clones of datetime_check_hour are:
lib/datetime/values.c datetime_check_minute
Threshold GRASS6 key metrics values at 2007-04-19 are:
median | upper | outlier |
| quartile | limit |
Complexity (Cyclo): 5 | 25 | 37 |
ParamNBR: 2 | 6 | 9 |
CalledNBR: 10 | 60 | 87 |
LOC: 43 | 195 | 273 |
LOC: Lines Of Code
Message interpretation:
OK : Nothing to say at all
* : above 75 % of value warning
Brought to you by:
