[GRASS-QA] GRASS QA: scott | ./grass6/display/d.rast.edit/main.c
|no clones | 0 monsters | 0 warnings
grass-qa at proxy.soccerlab.polymtl.ca
Fri Apr 20 00:06:59 EDT 2007
Hello scott,
ANALYSIS
display/d.rast.edit/main.c functions
main (Begins at: 30 Ends at: 124)
Complexity: | 7 | | OK |
ParamNBR: | 2 | | OK |
CalledNBR: | 33 | | OK |
LOC: | 95 | | OK |
metrics are OK
do_edit (Begins at: 127 Ends at: 163)
Complexity: | 4 | | OK |
ParamNBR: | 3 | | OK |
CalledNBR: | 10 | | OK |
LOC: | 37 | | OK |
metrics are OK
error (Begins at: 165 Ends at: 192)
CalledNBR: | 8 | | OK |
LOC: | 28 | | OK |
metrics are OK
ext (Begins at: 196 Ends at: 203)
Complexity: | 1 | | OK |
ParamNBR: | 1 | | OK |
CalledNBR: | 5 | | OK |
LOC: | 8 | | OK |
metrics are OK
Clone analysis:
This file does not contain cloned functions
Threshold GRASS6 key metrics values at 2007-04-19 are:
median | upper | outlier |
| quartile | limit |
Complexity (Cyclo): 5 | 25 | 37 |
ParamNBR: 2 | 6 | 9 |
CalledNBR: 10 | 60 | 87 |
LOC: 43 | 195 | 273 |
LOC: Lines Of Code
Message interpretation:
OK : Nothing to say at all
* : above 75 % of value warning
Brought to you by:
