[GRASS-QA] GRASS QA: scott | ./grass6/display/d.rast/main.c |4 clones ( main.c main.c )| 0 monsters | 0 warnings
Fri Apr 20 00:06:59 EDT 2007
Hello scott,
ANALYSIS
display/d.rast/main.c functions
main (Begins at: 31 Ends at: 138)
Complexity:   |       9 |       |      OK |
CalledNBR:    |      38 |     * |         |
LOC:          |     108 |       |      OK |
metrics are OK
parse_catlist (Begins at: 140 Ends at: 173)
Complexity:   |       6 |       |      OK |
CalledNBR:    |      10 |       |      OK |
LOC:          |      34 |       |      OK |
metrics are OK
parse_vallist (Begins at: 175 Ends at: 208)
LOC:          |      34 |       |      OK |
metrics are OK
parse_mask_rule (Begins at: 211 Ends at: 241)
ParamNBR:     |       3 |       |      OK |
CalledNBR:    |      11 |       |      OK |
LOC:          |      31 |       |      OK |
metrics are OK
parse_d_mask_rule (Begins at: 244 Ends at: 274)
LOC:          |      31 |       |      OK |
metrics are OK
Clone analysis:
This file has 4 potentially cloned functions:
  parse_d_mask_rule  parse_mask_rule  parse_vallist  parse_catlist
In display/d.rast/main.c clones of  parse_catlist are:
	raster/r.null/null.c  parse_vallist
	display/d.rast/main.c  parse_vallist
In display/d.rast/main.c clones of  parse_vallist are:
	display/d.rast/main.c  parse_catlist
In display/d.rast/main.c clones of  parse_mask_rule are:
	display/d.rast/main.c  parse_d_mask_rule
In display/d.rast/main.c clones of  parse_d_mask_rule are:
	display/d.rast/main.c  parse_mask_rule
Threshold GRASS6 key metrics values at 2007-04-19 are:
                           | quartile  | limit   |
ParamNBR:                2 |         6 |       9 |
CalledNBR:              10 |        60 |      87 |
LOC:                    43 |       195 |     273 |
 LOC: Lines Of Code
Message interpretation:
 OK : Nothing to say at all
Brought to you by:
