[GRASS-QA] GRASS QA: glynn | ./grass6/lib/gis/open_misc.c |no clones | 0 monsters | 0 warnings
Fri Apr 20 14:05:26 EDT 2007
Hello glynn,
ANALYSIS
lib/gis/open_misc.c functions
G__open_misc (Begins at: 32 Ends at: 105)
Complexity:   |      10 |       |      OK |
ParamNBR:     |       5 |     * |         |
CalledNBR:    |      21 |       |      OK |
LOC:          |      74 |       |      OK |
metrics are OK
G_open_new_misc (Begins at: 107 Ends at: 126)
Complexity:   |       1 |       |      OK |
ParamNBR:     |       3 |       |      OK |
CalledNBR:    |       2 |       |      OK |
LOC:          |      20 |       |      OK |
metrics are OK
G_open_old_misc (Begins at: 128 Ends at: 146)
ParamNBR:     |       4 |       |      OK |
CalledNBR:    |       1 |       |      OK |
LOC:          |      19 |       |      OK |
metrics are OK
G_open_update_misc (Begins at: 148 Ends at: 171)
Complexity:   |       2 |       |      OK |
CalledNBR:    |       3 |       |      OK |
LOC:          |      24 |       |      OK |
metrics are OK
G_fopen_new_misc (Begins at: 173 Ends at: 199)
LOC:          |      27 |       |      OK |
metrics are OK
G_fopen_old_misc (Begins at: 202 Ends at: 211)
LOC:          |      10 |       |      OK |
metrics are OK
G_fopen_append_misc (Begins at: 214 Ends at: 224)
CalledNBR:    |       4 |       |      OK |
LOC:          |      11 |       |      OK |
metrics are OK
G_fopen_modify_misc (Begins at: 226 Ends at: 236)
LOC:          |      11 |       |      OK |
metrics are OK
Clone analysis:
Threshold GRASS6 key metrics values at 2007-04-20 are:
                           | quartile  | limit   |
ParamNBR:                2 |         6 |       9 |
CalledNBR:              10 |        60 |      87 |
LOC:                    43 |       195 |     273 |
 LOC: Lines Of Code
Message interpretation:
 OK : Nothing to say at all
Brought to you by:
