[GRASS-QA] GRASS QA: glynn | ./grass6/lib/gis/open.c |no clones | 0
monsters | 0 warnings
grass-qa at proxy.soccerlab.polymtl.ca
Fri Apr 20 14:37:20 EDT 2007
Hello glynn,
ANALYSIS
lib/gis/open.c functions
G__open (Begins at: 86 Ends at: 158)
Complexity: | 10 | | OK |
ParamNBR: | 4 | | OK |
CalledNBR: | 21 | | OK |
LOC: | 73 | | OK |
metrics are OK
G_open_new (Begins at: 160 Ends at: 179)
Complexity: | 1 | | OK |
ParamNBR: | 2 | | OK |
CalledNBR: | 2 | | OK |
LOC: | 20 | | OK |
metrics are OK
G_open_old (Begins at: 181 Ends at: 199)
ParamNBR: | 3 | | OK |
CalledNBR: | 1 | | OK |
LOC: | 19 | | OK |
metrics are OK
G_open_update (Begins at: 201 Ends at: 224)
Complexity: | 2 | | OK |
CalledNBR: | 3 | | OK |
LOC: | 24 | | OK |
metrics are OK
G_fopen_new (Begins at: 226 Ends at: 252)
LOC: | 27 | | OK |
metrics are OK
G_fopen_old (Begins at: 255 Ends at: 264)
LOC: | 10 | | OK |
metrics are OK
G_fopen_append (Begins at: 267 Ends at: 277)
CalledNBR: | 4 | | OK |
LOC: | 11 | | OK |
metrics are OK
G_fopen_modify (Begins at: 279 Ends at: 289)
LOC: | 11 | | OK |
metrics are OK
Clone analysis:
This file does not contain cloned functions
Threshold GRASS6 key metrics values at 2007-04-20 are:
median | upper | outlier |
| quartile | limit |
Complexity (Cyclo): 5 | 25 | 37 |
ParamNBR: 2 | 6 | 9 |
CalledNBR: 10 | 60 | 87 |
LOC: 43 | 195 | 273 |
LOC: Lines Of Code
Message interpretation:
OK : Nothing to say at all
* : above 75 % of value warning
Brought to you by:
