[GRASS-QA] GRASS QA: glynn | ./grass6/display/d.text/main.c |no clones | 0 monsters | 3 warnings
Fri Apr 20 14:47:18 EDT 2007
Hello glynn,
ANALYSIS
display/d.text/main.c functions
main (Begins at: 41 Ends at: 266)
Complexity:   |      32 |    ** | Warning |
CalledNBR:    |      84 |    ** | Warning |
LOC:          |     226 |    ** | Warning |
at least 3 values are close to an outlier please consider revising code
Clone analysis:
Threshold GRASS6 key metrics values at 2007-04-20 are:
                           | quartile  | limit   |
ParamNBR:                2 |         6 |       9 |
CalledNBR:              10 |        60 |      87 |
LOC:                    43 |       195 |     273 |
 LOC: Lines Of Code
Message interpretation:
 OK : Nothing to say at all
Brought to you by:
