[GRASS-QA] GRASS QA: glynn | ./grass6/display/d.text.new/main.c |no
clones | 3 monsters | 2 warnings
grass-qa at proxy.soccerlab.polymtl.ca
Fri Apr 20 14:47:18 EDT 2007
Hello glynn,
ANALYSIS
display/d.text.new/main.c functions
main (Begins at: 78 Ends at: 572)
Complexity: | 63 | *** | MONSTER |
ParamNBR: | 2 | | OK |
CalledNBR: | 141 | *** | MONSTER |
LOC: | 495 | *** | MONSTER |
3 metric are OUT OF RANGE!
set_color (Begins at: 574 Ends at: 596)
Complexity: | 4 | | OK |
ParamNBR: | 1 | | OK |
CalledNBR: | 8 | | OK |
LOC: | 23 | | OK |
metrics are OK
get_coordinates (Begins at: 599 Ends at: 647)
Complexity: | 8 | | OK |
ParamNBR: | 9 | *** | MONSTER |
CalledNBR: | 17 | | OK |
LOC: | 49 | | OK |
at least 1 values are close to an outlier please consider revising code
draw_text (Begins at: 649 Ends at: 724)
Complexity: | 15 | | OK |
ParamNBR: | 7 | ** | Warning |
CalledNBR: | 12 | | OK |
LOC: | 76 | | OK |
Clone analysis:
This file does not contain cloned functions
Threshold GRASS6 key metrics values at 2007-04-20 are:
median | upper | outlier |
| quartile | limit |
Complexity (Cyclo): 5 | 25 | 37 |
ParamNBR: 2 | 6 | 9 |
CalledNBR: 10 | 60 | 87 |
LOC: 43 | 195 | 273 |
LOC: Lines Of Code
Message interpretation:
OK : Nothing to say at all
* : above 75 % of value warning
Brought to you by:
