[GRASS-QA] GRASS QA: hamish | ./grass6/vector/v.distance/main.c |no
clones | 3 monsters | 0 warnings
grass-qa at proxy.soccerlab.polymtl.ca
Sun Apr 22 05:38:14 EDT 2007
Hello hamish,
ANALYSIS
vector/v.distance/main.c functions
main (Begins at: 68 Ends at: 1039)
Complexity: | 161 | *** | MONSTER |
ParamNBR: | 2 | | OK |
CalledNBR: | 315 | *** | MONSTER |
LOC: | 972 | *** | MONSTER |
3 metric are OUT OF RANGE!
cmp_near (Begins at: 1042 Ends at: 1049)
Complexity: | 3 | | OK |
CalledNBR: | 0 | | OK |
LOC: | 8 | | OK |
metrics are OK
cmp_exist (Begins at: 1052 Ends at: 1060)
LOC: | 9 | | OK |
metrics are OK
Clone analysis:
This file does not contain cloned functions
Threshold GRASS6 key metrics values at 2007-04-22 are:
median | upper | outlier |
| quartile | limit |
Complexity (Cyclo): 5 | 25 | 37 |
ParamNBR: 2 | 6 | 9 |
CalledNBR: 10 | 60 | 87 |
LOC: 43 | 195 | 273 |
LOC: Lines Of Code
Message interpretation:
OK : Nothing to say at all
* : above 75 % of value warning
Brought to you by:
