[GRASS-QA] GRASS QA: hamish | ./grass6/lib/gis/parser.c |no clones
| 1 monsters | 9 warnings
grass-qa at proxy.soccerlab.polymtl.ca
Sun Apr 22 05:49:54 EDT 2007
Hello hamish,
ANALYSIS
lib/gis/parser.c functions
G_disable_interactive (Begins at: 160 Ends at: 181)
Complexity: | 1 | | OK |
ParamNBR: | 1 | | OK |
CalledNBR: | 0 | | OK |
LOC: | 22 | | OK |
metrics are OK
G_define_flag (Begins at: 184 Ends at: 242)
Complexity: | 3 | | OK |
CalledNBR: | 4 | | OK |
LOC: | 59 | | OK |
metrics are OK
G_define_option (Begins at: 245 Ends at: 327)
LOC: | 83 | | OK |
metrics are OK
G_define_standard_option (Begins at: 330 Ends at: 571)
Complexity: | 28 | ** | Warning |
CalledNBR: | 31 | | OK |
LOC: | 242 | ** | Warning |
at least 2 values are close to an outlier please consider revising code
G_define_module (Begins at: 574 Ends at: 626)
CalledNBR: | 1 | | OK |
LOC: | 53 | | OK |
metrics are OK
G_parser (Begins at: 628 Ends at: 893)
Complexity: | 37 | *** | MONSTER |
ParamNBR: | 2 | | OK |
CalledNBR: | 74 | ** | Warning |
LOC: | 266 | ** | Warning |
at least 3 values are close to an outlier please consider revising code
uses_new_gisprompt (Begins at: 896 Ends at: 946)
Complexity: | 5 | | OK |
CalledNBR: | 2 | | OK |
LOC: | 51 | | OK |
metrics are OK
G_usage (Begins at: 948 Ends at: 1134)
Complexity: | 33 | ** | Warning |
CalledNBR: | 53 | * | |
LOC: | 187 | * | |
at least 1 values are close to an outlier please consider revising code
print_escaped_for_xml (Begins at: 1136 Ends at: 1152)
Complexity: | 6 | | OK |
LOC: | 17 | | OK |
metrics are OK
G_usage_xml (Begins at: 1154 Ends at: 1368)
CalledNBR: | 71 | ** | Warning |
LOC: | 215 | ** | Warning |
G_usage_html (Begins at: 1370 Ends at: 1601)
Complexity: | 43 | *** | MONSTER |
CalledNBR: | 78 | ** | Warning |
LOC: | 232 | ** | Warning |
1 metric are OUT OF RANGE!
G_script (Begins at: 1603 Ends at: 1714)
Complexity: | 22 | * | |
CalledNBR: | 46 | * | |
LOC: | 112 | | OK |
metrics are OK
generate_tcl (Begins at: 1716 Ends at: 1802)
Complexity: | 10 | | OK |
CalledNBR: | 34 | | OK |
LOC: | 87 | | OK |
metrics are OK
G_gui (Begins at: 1805 Ends at: 1834)
CalledNBR: | 8 | | OK |
LOC: | 30 | | OK |
metrics are OK
G_tcltk (Begins at: 1837 Ends at: 1852)
LOC: | 16 | | OK |
metrics are OK
show_options (Begins at: 1854 Ends at: 1883)
Complexity: | 4 | | OK |
CalledNBR: | 10 | | OK |
LOC: | 30 | | OK |
metrics are OK
show (Begins at: 1885 Ends at: 1898)
CalledNBR: | 3 | | OK |
LOC: | 14 | | OK |
metrics are OK
set_flag (Begins at: 1900 Ends at: 1927)
LOC: | 28 | | OK |
metrics are OK
contains (Begins at: 1932 Ends at: 1941)
LOC: | 10 | | OK |
metrics are OK
set_option (Begins at: 1943 Ends at: 2003)
CalledNBR: | 13 | | OK |
LOC: | 61 | | OK |
metrics are OK
check_opts (Begins at: 2005 Ends at: 2042)
LOC: | 38 | | OK |
metrics are OK
check_an_opt (Begins at: 2044 Ends at: 2086)
ParamNBR: | 4 | | OK |
LOC: | 43 | | OK |
metrics are OK
check_int (Begins at: 2088 Ends at: 2154)
Complexity: | 13 | | OK |
CalledNBR: | 6 | | OK |
LOC: | 67 | | OK |
metrics are OK
check_double (Begins at: 2156 Ends at: 2196)
LOC: | 41 | | OK |
metrics are OK
check_string (Begins at: 2198 Ends at: 2225)
Complexity: | 8 | | OK |
LOC: | 28 | | OK |
metrics are OK
check_required (Begins at: 2227 Ends at: 2250)
LOC: | 24 | | OK |
metrics are OK
split_opts (Begins at: 2252 Ends at: 2315)
LOC: | 64 | | OK |
metrics are OK
check_multiple_opts (Begins at: 2317 Ends at: 2355)
CalledNBR: | 5 | | OK |
LOC: | 39 | | OK |
metrics are OK
check_overwrite (Begins at: 2358 Ends at: 2414)
Complexity: | 11 | | OK |
CalledNBR: | 11 | | OK |
LOC: | 57 | | OK |
metrics are OK
interactive (Begins at: 2416 Ends at: 2444)
LOC: | 29 | | OK |
metrics are OK
interactive_flag (Begins at: 2446 Ends at: 2454)
LOC: | 9 | | OK |
metrics are OK
interactive_option (Begins at: 2456 Ends at: 2546)
Complexity: | 23 | * | |
CalledNBR: | 41 | * | |
LOC: | 91 | | OK |
metrics are OK
split_gisprompt (Begins at: 2548 Ends at: 2578)
LOC: | 31 | | OK |
metrics are OK
gis_prompt (Begins at: 2580 Ends at: 2637)
CalledNBR: | 20 | | OK |
LOC: | 58 | | OK |
metrics are OK
G_recreate_command (Begins at: 2639 Ends at: 2741)
CalledNBR: | 25 | | OK |
LOC: | 103 | | OK |
metrics are OK
Clone analysis:
This file does not contain cloned functions
Threshold GRASS6 key metrics values at 2007-04-22 are:
median | upper | outlier |
| quartile | limit |
Complexity (Cyclo): 5 | 25 | 37 |
ParamNBR: 2 | 6 | 9 |
CalledNBR: 10 | 60 | 87 |
LOC: 43 | 195 | 273 |
LOC: Lines Of Code
Message interpretation:
OK : Nothing to say at all
* : above 75 % of value warning
Brought to you by:
