[GRASS-QA] GRASS QA: hamish | ./grass6/vector/v.in.ascii/a2b.c |no
	clones | 0 monsters | 1 warnings
    grass-qa at proxy.soccerlab.polymtl.ca
    Tue Apr 24 05:06:07 EDT 2007
Hello hamish,
ANALYSIS
vector/v.in.ascii/a2b.c functions
asc_to_bin (Begins at: 9 Ends at: 168)
Complexity:   |      29 |    ** | Warning |
CalledNBR:    |      40 |     * |         |
LOC:          |     160 |     * |         |
at least 1 values are close to an outlier please consider revising code
Clone analysis:
Threshold GRASS6 key metrics values at 2007-04-24 are:
                           | quartile  | limit   |
ParamNBR:                2 |         6 |       9 |
CalledNBR:              10 |        60 |      87 |
LOC:                    43 |       195 |     273 |
 LOC: Lines Of Code
Message interpretation:
 OK : Nothing to say at all
Brought to you by:
