[GRASS-QA] GRASS QA: scott | ./grass6/lib/db/dbmi_base/xdr.c |no
clones | 0 monsters | 0 warnings
grass-qa at proxy.soccerlab.polymtl.ca
Thu Apr 26 13:42:53 EDT 2007
Hello scott,
ANALYSIS
lib/db/dbmi_base/xdr.c functions
db__set_protocol_fds (Begins at: 21 Ends at: 25)
Complexity: | 1 | | OK |
ParamNBR: | 2 | | OK |
CalledNBR: | 0 | | OK |
LOC: | 5 | | OK |
metrics are OK
xdr_begin_send (Begins at: 28 Ends at: 33)
ParamNBR: | 1 | | OK |
CalledNBR: | 1 | | OK |
LOC: | 6 | | OK |
metrics are OK
xdr_begin_recv (Begins at: 36 Ends at: 41)
LOC: | 6 | | OK |
metrics are OK
xdr_end_send (Begins at: 44 Ends at: 50)
Complexity: | 3 | | OK |
CalledNBR: | 2 | | OK |
LOC: | 7 | | OK |
metrics are OK
xdr_end_recv (Begins at: 53 Ends at: 58)
LOC: | 6 | | OK |
metrics are OK
Clone analysis:
This file does not contain cloned functions
Threshold GRASS6 key metrics values at 2007-04-26 are:
median | upper | outlier |
| quartile | limit |
Complexity (Cyclo): 5 | 25 | 37 |
ParamNBR: 2 | 6 | 9 |
CalledNBR: 10 | 60 | 87 |
LOC: 43 | 195 | 273 |
LOC: Lines Of Code
Message interpretation:
OK : Nothing to say at all
* : above 75 % of value warning
Brought to you by:
