[GRASS-QA] GRASS QA: scott | ./grass6/lib/db/dbmi_client/column.c |no clones | 0 monsters | 0 warnings
Thu Apr 26 13:42:54 EDT 2007
Hello scott,
ANALYSIS
lib/db/dbmi_client/column.c functions
db_column_sqltype (Begins at: 35 Ends at: 69)
Complexity:   |       3 |       |      OK |
ParamNBR:     |       3 |       |      OK |
CalledNBR:    |       9 |       |      OK |
LOC:          |      35 |       |      OK |
metrics are OK
db_column_Ctype (Begins at: 72 Ends at: 92)
Complexity:   |       2 |       |      OK |
CalledNBR:    |       2 |       |      OK |
LOC:          |      21 |       |      OK |
metrics are OK
db_get_column (Begins at: 95 Ends at: 140)
ParamNBR:     |       4 |       |      OK |
CalledNBR:    |      18 |       |      OK |
LOC:          |      46 |       |      OK |
metrics are OK
Clone analysis:
Threshold GRASS6 key metrics values at 2007-04-26 are:
                           | quartile  | limit   |
ParamNBR:                2 |         6 |       9 |
CalledNBR:              10 |        60 |      87 |
LOC:                    43 |       195 |     273 |
 LOC: Lines Of Code
Message interpretation:
 OK : Nothing to say at all
Brought to you by:
